1 - 9 of 9 Posts
Banned
I need a program recommendation for a Blu-ray ripper and then a program to convert the ripped files to avi/mkv`s.
Any free programs? Good paid ones also at a reasonable price...
I moved your post to the HTPC forum, since this is the right place.
I will recommend ArcSoft's Total Media Theater for Blu-Ray and MKV playback. I had tried to use PowerDVD Ultra/9 since it came with my BD drive and I even paid for the upgrade to the full retail version, but is, IMNHSO is POS.
ArcSoft on the other hand has worked flawlessly on my setup.
Banned
Thanks for the suggestion, I have a playback program actually it is PowerDVD 8 and it works well...What I am asking for is a ripper and converter.
Banned
Discussion Starter · #7 ·
Another way to go if you want a 1:1 copy c/w HD audio is to use MakeMKV's it's currently a free beta that I've used with great success. It does the decrypting and then put's into an mkv all in one program.
Coop nice little program did u buy it or does the 30 day trail go on forever? Let me know. Not sure if I need 1:1 conversion decryption......thanks everybody for all the suggestions...I will play with them all!!
1 - 9 of 9 Posts
