anchoi said:
Would you consider buying a AVIA or DVE DVD, you can calibrate it yourself? Just a thought!
What about knowledge of the service menu adjustments?
Your suggestion is OK for the average consumer to adjust the user menu settings... often these are not enough to correct inherent faulty factory settings... colour push, greyscale.
I bought an expensive Sony direct view CRT and was surprised how much difference the calibrator was able to achieve by getting into the internal greyscale setup etc. I had done my own adjustments using the THX tools on a DVD.
What the calibrator did for me was to set my TV to give the same colour display for all my inputs:
DVD @ 1080i upconverted by my DVD
HD Cable @ 1080i
Antenna @ 1080i for OTA HD
Cable input at NTSC for regular cable feed
http://www.sentex.ca/~mjlevy/Calibration.jpg
This shows the change from before (unskilled me with DVD) to the after by the Tech.
Changes within the circle cannot be spotted by the human eye.
If you are getting a well known tech from Calgary you will be getting one of the best in North America..... I wouldn't think twice about it.
Note I was extremely happy with my TV out of the box compared to my prior TV's and what I see in stores..... after the calibrator left I couldn't believe the difference. The clarity depth within darker, contrasty scenes is amazing.
I don't regret the $$ I spent.... even my wife was amazed and she really was v. happy before.
If you care about what you are seeing then calibration is an investment everyone should make... I feel little need to see any movie at the cinema... my DVD experience is now visually perfect.
