Hi All,
I have recently upgraded my Vista 64-bit Media Center to Windows 7 Media Center, also 64-bit. Ever since I changed the OS, my Hauppauge ATSC tuners would at times inexplicably shut off. Generally, I have my Digital Signal Strength Indicators (wintv_sigmon.exe) turned on for both tuners to monitor their signal strengths. At most times, both indicator are green, indicating strong signals. Sometimes, having left the computer running for a while, without having Media Center turned on, one or both signal would die completely, with one or both indicators becoming black. When this happens, scheduled recordings are obviously skipped, unless one tuner is left on. Sometimes, this behaviour occurs while Media Center is on and in the middle of a recording. The tuner recording a program would die all of a sudden, and Media Center would continue recording a blank signal.
Some observations to note:
One thing I haven't tried is to roll back to older Hauppauge drivers. Do you think that would help? Any suggestions as to how I may solve this problem are greatly appreciated!
- Signal Strength indicators turning black is not due to a weak OTA signal, because the tuners are tuned to the most reliable channels available.
- I can make the ASTC tuners turn back on if I first change to an analog channel then switch back to a digial channel. Indicator would then switch from black to green.
- This behaviour did not occur with Vista Media Center
- Standby and Hibernate are disabled.
- Lastest Hauppauge drivers are used: 22xxdrv_27223.zip
- Used Peter Near's instructions to enable ASTC here in Toronto: http://thegreenbutton.com/blogs/pne...atsc-amp-qam-in-canada-for-windows-7-rtm.aspx
