I have a low hr SHARP AQUOS LC42D43U, it's 2.5 yr's old and it has developed a vertical black line right in middle of the panel, "burn" is not a possibility, any ideas ?
I'm not impressed with the standard 1 whopping year warranty.
Sorry if I have this posted in the incorrect spot.
Would anyone be able to tell me why I not able to view DVD or my Wii on my TV. As far as I can tell by following the manual I have the connections hooked up correctly.
The wii is connected with audio/video cables and the DVD with component cables in component section 2 and 3. The tv is not recognizing they are there. Any help would be appreciated.
I have a Sharp Aquos LC42LE620UT
Thanks in advance Deb
I'm unfamiliar with that exact model but some Sharp have input-skip function. Is it possible that the input skip for those inputs have been disabled? In the worst case scenario, there is a factory default option in the menu and you can try to bring everything to factory default and see whether the problem persists.
Whereabouts are you located? If it's around my area or if I'm on my way, I can just stop by to troubleshoot.
I have tried switching to both inputs 2 and 3 and input 1 for the wii. All I see on my screen is no signal. I have no problem viewing my Cable on input 5.
A forum community dedicated to Canadian TV, computing and home theatre owners and enthusiasts. Come join the discussion about home audio/video, displays, troubleshooting, styles, projects, DIY’s, product reviews, accessories, classifieds, and more!
