I use VOIP (w/ Vonage) for my phone and am unable to connect two lines to my phone adapter (no space to fit a splitter).
So, to order PPV I usually unhook my phone line and hook up my 630 to the voip adapter.
Can anyone tell me how long the 630 needs to be connected to the phone line to order and record a PPV movie?
Usually I connect the 630, order the movie then force a reportback and disconnect the 630. Then after I have watched the movie I usually reconnect the 630 to do another reportback so that the movie goes into my purchase history.
However, when I did this last week, the movie I had ordered will not play past the 6 minute point, even though it says it recorded the full 2 hours.
I'm not sure if it's because it wasn't connected to a phone line while recording, or if the 630 just screwed up and it's a bad recording.
Must I be connected to a phone line when the movie begins and while it records or am I fine so long as I've forced a reportback after ordering it? (In this case I ordered it the day before it was on.)
Any help would be appreciated. CSRs just tell me I have to be connected all the time which is not helpful.
