Does anyone know if such a product exists. I need to run cable connection to another room on the second floor. I rather do this without using cables, does anyone know if there is an adapter that I can plug into the electrical outlet which converts coax connections from my cable providers signal and then I can plug in the adapter in the other room and then connect it to my digital box?
Kind of like an Ethernet powerline adapter but with coax connections.
It's a long shot but I figured this is the best place to ask.
T.
T.
