1 - 20 of 35 Posts
This may be a simple question, but I am a newbie to this. I have noticed a wide range in power ratings between receivers. Some Sony receivers are rated at 1000W while a Harmon-Kardon may be rated and half that. This doesn't mean it's twice as powerful, right? I'm guessing that not all watts are created equal. If this is true, how do you know what power rating to look for. I have some speakers that can take 140Watts, does that mean a reciever pumping out 100W per channel is going to be better then one pumping out 55W?
Vernon
Watts are equal, what's not equal is the specification:
- Total Watts - no distortion number given
- Total Watts - a high distortion number
- Total Watts - a low distortion number
- Watts per channel, no distortion or frequency response given, no indication of number of channels driven
- Watts per channel, two channels driven, at 1 kHz
- Watts per channel, all channels driven, 20-20kHz, 0.05% distortion.
The above is an indication of the loosest spec to the tightest. The Wattage difference could be as much as a factor of 10 or 100 between the top and the bottom. It only makes sense since a $200 HTiB rated at 1000W is simply not even going to be close to an AVR rated similarly, but all channels driven, 20-20kHz, low distortion that costs $2000.
By way of example, a $200 HTiB rated at 1000W, may not even be able to produce 1W/ch, 20-20kHz, 0.05% distortion. Basically, you get roughly what you pay for and Watts should be one of your last concerns when picking out an AVR - see:
http://www.digitalhome.ca/forum/showthread.php?t=76082 AVR Features
See the following previous thread on the topic:
http://www.digitalhome.ca/forum/showthread.php?t=27306
Speakers should also have 2 power ratings:
1) x Watts at y% distortion which will be a lot smaller than 2 below
2) z Watts before damage (smoke power rating)
The power rating you usually see on speakers is #2 - the "smoke" (damage) rating.
double the power for 3db
What feels like twice as loud is ten times the power! A 3db increase can be confidently noticed by a novice and that takes twice the power. 1 watt becomes 2 and 600 becomes 1200. And sound should be dynamic. peaks and soft parts. Do you have reserve power for the peaks. If your source is poorly made CD's and MP3's there is no dynamics to concern your self with. Music that sounds like a steady tone has no need for life like capable reserves of power.
Published Versus Tested
I noticed these statistics in the July 2008 HOME THEATRE magazine.
For a Denon AVR-3808, published at 130 watts/channel, tested into 5 channels at 0.1% distortion - 118.9 watts/channel, and at 1% distortion, 138 watts/channel. This AVR weighs 39 pounds.
For a Yamaha RX-V863, published at 105 watts/channel, tested into 5 channels at 0.1% distortion, 42.6 watts/channel, and at 1% distortion, 48.4 watts/channel. This AVR weighs 26 pounds.
Everything into 8 Ohms.
Obviously the Denon costs more, but Yamaha is not a fly-by-night manufacturer. It's puzzling why they fudge their published numbers.
Remember, weight is the quick, no instruments required, test.
What are numbers for all channels driven; .1% distortion, 20 to 20k?
You can be sure that they are less than 119 & 42 watts quoted in the article.
Only companies like NAD, H/K, B&K, Outlaw, Sunfire, Emotiva and high end companies admit to the 1972 FCC standards.
All Channels Driven
Yamaha RX-V863 - 41.6 watts/channel @ 0.1% distortion
Denon AVR-3808CI - 113.5 watts/channel @ 0.1% distortion
Not significantly differently from 5 channels driven.
A power rating at 1 frequency is not the same as a power rating across the whole audio spectrum. It could be up to 20% lower when measured 20 to 20k.
My HK has two ratings: stereo mode (55W/ch) and 5-channel (45W/ch). The power supply is usually the limiting factor. It can't always drive all the channels at full power which is what reviewers like to measure.
I disagree with 57 that Watts should be one of your last concerns when picking out an AVR. With my stereo steup there's a noticable different between my 60W/ch Kenwood and my 110W/ch Quad. Even at low volumes the Quad sounds better (cleaner, crisper low end). A sub changes that dynamic since that's where you need the power. Is there a rule-of-thumb for sizing a sub? I'd guess that the sub should be 5x to 10x the per channel power of the AVR.
In the old day they'd specify rms or average or peak (am I dating myself?)
What is it they specify these days and do all of them specify the same measurement (or are some watts rms while others are peak).
Remember the old days RMS, Both channels driven from 20 to 20,000 at .1% distortion, well today if your receiver has only one transformer and if it was just playing stereo music, both channels driven could be say 150 watts. Now put in a movie and fire up the 5.1 which = 6 channels at once or 7.1 = 8 channels at the same time. That’s like 4 amps running from 1 power supply. Can you run 8 deep freezers or 8 stoves at once at home without blowing a fuse? But not all 8 get the same amount of work. The rear and side speakers whisper to suggest your in a big room or your outside while the front three speakers are suppose to shout, thump, crash and carry all the talking. How would you rate a receiver? Eight speakers full power (like it never does happen in movies or surround music) or just drive three speakers RMS from 20 to 20,000 at .1% Remember the undistorted difference between 150 watts and 75 watts is 3db and you would strain to hear that. Does that help any?
>>>But not all 8 get the same amount of work. The rear and side speakers whisper to suggest your in a big room or your outside while the front three speakers are suppose to shout, thump, crash and carry all the talking.<<<
Do the newer audio formats generally give the surround channels more work to do than the older DTS/DD (non-HDMI) formats, since you can now get 5-7 full channels of sound now?
The new formats have nothing to do with comparisons to DD5.1 or DTS (5.1). If the movie or concert mix sent a lot of sound to the right surround for example, then more power would be required there. The new formats don't send more sound, they just send an uncompressed signal (cleaner). The amount of audio sent to the surrounds is usually less than is sent to the fronts, but that depends on the mix, not the type of signal.
Some movies use the surrounds sparingly, while some make extensive use.
That is like saying a 100lb amp is going to be more powerful than a 60lb amp. I can show you many amps that will prove this completely false.
Weight is not a guide to measure power, it is only a mere indication and at times not the truth. It however is true enough of the time that it's become a generalization....but generalizations are not fact.
Real Specifications
The best Indicator are the Real Specifications, and even then, they have to be taken with a grain of salt. These look good on the surface, but notice what's missing? Nowhere ever does it say 'all channels driven', it only lists 2 channels at a time.
This is sold as 130 watts per channel, 910 total. I call it 110. But then i have 6 ohm speakers.....
Amplifier section
Continuous average power output of 110 watts* per
channel, min., at 8 ohms, from 20 Hz to 20 000 Hz
with no more than 0.09 %** total harmonic
distortion (front).
Continuous Power Output (20 Hz to 20 kHz, 8 Ω, 0.09 %)
Front. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 110 W + 110 W
Center . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 110 W
Surround . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 110 W + 110 W
Surround back . . . . . . . . . . . . . . . . . . . . . . . . 110 W + 110 W
Continuous Power Output (1 kHz, 6 Ω, 1.0 %)
Front. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 150 W + 150 W
Center . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 150 W
Surround . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 150 W + 150 W
Surround back . . . . . . . . . . . . . . . . . . . . . . . . 150 W + 150 W
Related Power Output (1 kHz, 8 Ω, 0.05 %)
Front. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 130 W per channel
Center . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 130 W
Surround . . . . . . . . . . . . . . . . . . . . . . . . . . 130 W per channel
Total harmonic distortion. . . . . . . . . . . . . . . . . . . . . . . . 0.09 %
(20 Hz to 20 kHz, 110 W, 8 Ω)
* Measured pursuant to the Federal Trade Commission’s
Trade Regulation rule on Power Output Claims for Amplifiers
** Measured by Audio Spectrum Analyzer
So, I played a full CD (hard Rock music) stereo only, (only the 2 speakers) at 0 volume and the thing got almost hot enough to fry an egg. I was worried about the heat, but it didn't hurt it and it didn't shut down.
About 20 years ago, there was an audio show in Hamilton. NAD hooked up two stereo amplifiers, one was another major brand (which I forgot now) and second was NAD. They played piano music on both and connected a scope across the load.
The "other" brand was rated much higher than NAD what it had lower dynamic headroom. Most of the music was around 20 watts but some peaks were clipping at 140 watts. On the NAD, you could see these peaks hitting 170-180 watts. NAD had dynamic power rating of 200 watts.
I own a NAD 7400 receiver. It has 2.7db headroom and it can pump 440 watt peaks into 2 ohms. No wonder, I can get half the money I paid for it 19 years ago (not that I would sell it), but I can't even get one sixth for my seven year old Denon 3801.
The main two channels of my home theater are powered by the original NAD 3020 a whopping 28 watts. And I use it as phantom center channel. Of course here is a powered sub and the Denon Receiver powers the rear. Do I feel the need for more Watts, sorry not at all. Poor designed power supplies and overly aggressive protection circuits eat your dynamic range for breakfast.
From the link below, Yamaha claimes 130 W/ch with certain qualifiers. My guess is that this AVR could probably give you 130 W/ch, 2 channels driven at the specs, and about 100 W/ch 5 channels driven at the specs
http://www.yamaha.ca/av/Receivers/HTR6190B.jsp
As stated in post 2 of this thread, it's the qualifiers that are important and if you don't know how to interpret the qualifiers, the W/ch number is meaningless.
For example, lots of $200 HTiBs promote 100 W/ch, but without any specs. Those same HTiBs would be hard pressed to give 1 W/ch at the same distortion level as the Yamaha at "full power".
Please note that there are lots of things that can be more important than amplifier power numbers. See the following post for example:
And the following post, useful for those new to the forum - FAQs, Search Tips, Optimization, etc.
1 - 20 of 35 Posts
