Looks nice, congrats.
Can I ask you how much $$$ it cost to put it all together and how much more $$$ your still planning on putting into it, just curious.
I added up the receipts yesterday.... The total project cost after taxes about $12,000 (give or take 5%).
A brief pictoral (not very well kept - sorry) can be found here:
http://www.pjbj.ca/labels/basement.html
a rough drawing of the layout is found here:
For the rough break down of dollars.
Soundproofing materials - including the clips, green glue, insulation, weatherstripping for doors, caulking
(but not including the 2nd layer of drywall ) was $2903
Drywall materials (inc. 2nd layer) I used about 80 sheets of drywall total - tape, mud, screws, super6, and 1/3rd of a ebay drywall lift was $1726
Framing materials - lumber, screws, nails for pneumatic framing gun, shopvac bags, shims etc etc $870
Electrical materials - IR dimmers, switches, boxes, 2 new circuit breakers, romex, lights, cat5 cable, 5g6 was $834
Doors - safe and sound- 2 x32", 1 x 31.75" wide, finger jointed pine for extra thick door jambs (none of my jambs are 'standard' thicknesses) stops, door knobs, 9 hinges - $681
Some new tools on sale - Makita 18v lithium 4 pack (hammer drill, impact driver, reciprating saw (Mr. Fix it), worklight), Ridgid 16g Finish Nailer, couple roller stands - $749
Carpet and install - 450 sq ft - $1350
Paint / Primer - Benjamin Moore - roughly $50-60/gallon - $400
Materials for screen and stereo stand, PJ mount: $228
Electronic goodies - Epson HC720, monoprice cables, Paradigm cc290(center channel), DSP3100 subwoofer $2255
Next 3-6 months:
Currently, we are using some old furniture in the room. I have my eye out on a 4 seater reclining (leather) HT couch, but will wait a few months before we buy that.... will see what the xmas bills are like. I estimate the couch will cost between $3000-4000cdn. Construction wise I only have to box in the lolly, that'll be about $30 for a sheet of MDF and some leftover paint. I would like to add a 2nd door in the main entrance that leads directly upstairs to the main floor and 2nd floor ( we have a winding stair case, and the stair well goes up to the 2nd floor) The door and hardware if I can find it on sale will be about $100-120. Home depot has solid pine doors for about $70, and I can trim down a 32" door to fit my wonky 31.25" jamb. Sound treatment panels and bass traps for the walls should be about $100-200 for materials (appropriate insulation, framing materials and upholstery)
re: clips
I bought the clips and glue in Mississauga. The glue was about $17+tax/tube, and I believe the clips were about $6-7 each. Google Green glue and Kinetics Isomax clips to find the name of the distributer.
P
