1 - 20 of 77 Posts
Just thought I would mention how much it costs to import this hot new reciever into Canada for any interested parties
Total after shipping,duties and taxes total $655.28
I ordered from J&R.com had to call in the order as it is not on the web site yet. It was $429.99us plus $75.78us for shipping then duties was $36.56can
it litterally got here OVERNIGHT too! shipped out last night at 4:58pm from New York and I had it in my hands today at 11:03am.
WMA-9 decoding and component vid upconversion
http://www.pioneerelectronics.com/pna/product/detail/0,,2076_4153_209686388,00.html
The main high light is WMA 9 decoding and component video upconversion of all inputs to one single component output!,
but other than that, its a high current mosfet amp with 120watt into all 7 channels, THX certified, automatic room tuning microphone for set up, 48 bit DSP chip, and lots lots more.
The predecesosr for it the vsx-1014tx was and still is considered one of the best valued recievers on the market to date.
I don't think I've ever seen an option to output a raw compressed bitstream on any software I've used, though. For example, I use MusicMatch and any song I play with that software will be output as PCM, meaning the computer has already decoded the WMA bitstream.
Discussion Starter · #12 ·
From what I remember the pcm and optical output are not decoded, the analog outputs yes but digital outputs are just that digital and therefor undecoded. Just set your digital output to be set as passthru. Same as outputing the dolby digital of dts out of a computer, it gos uncompressed to the reciver in the digital domain, then the reciever processes the stream
From what I remember the pcm and optical output are not decoded...
That's not correct. I can take the optical output from my computer and connect it up to ANY receiver and it will play. PCM would be a bitstream that's already decoded. A DVD player will output a raw dolby digital or DTS bitstream, but not a raw MP3 bitsteam.
The H/K receivers used to (I think some still do) have the ability to decode MP3, but they required a computer peripheral and software (DAL-150) to get a raw undecoded bitstream into the receiver. I'd just like to know how Pioneer is doing it.
Discussion Starter · #16 ·
I will check avsforum to see if they have and answer yet. If I knew someone in town with bell i could test it out but I dont know anyone at the moment that has bell. I have it but thru dvr card not stb.
RyanW said:
ctown6412, do you happen know if they have fixed the bug with the optical and coxial output not working with expressvu and dishnetwork recievers?
MOved this to Pioneer Forum as its more about the unit than any deals (however, I have left the redirect)
I just noticed BEV has released new software for 6100 model receivers that includes a fix to make the digital output "compatable with all home theatre systems. Perhaps the other receiver will also be "fixed" soon.
Banned
Shrugs
painter said:
Is it compatible with 4 ohm speakers or just 8ohm?
Hmm how do I know what OHM my front speakers are? I don't have the specs for them. I have a front pair of Energy model number e:XL-25B-1
My rear speakers are 8ohm. So these speakers may work with Pioneer receivers?
Hmm nevermind, I manage to find info. my fronts are 8ohm as well.
1 - 20 of 77 Posts
