721 - 725 of 725 Posts
Just so you know, that device will give you about 3.5dB of signal loss. Unless the antennas are aimed in significantly different directions, you will be much better off with only the one antenna.
my rooftop setup
so this can be a "proof it can be done", here's two pics of my a-d 91xg mounted using a j-mount (a-d stm-1000). i mounted it last oct-nov (2012); it survived the 2012-13 winter and some pretty strong winds we had recently.
i would add that a proper base / anchoring of the j-mount is essential to keep the whole assembly in place. in my case, it's 5 2x4s forming a block between two roof trusses -- see 3rd picture. (the four arrows point to the holes for the lag bolts.)
ok..does anyone has a reputable or recommend installer in Toronto to introduce? i'm at finch and don mills area...thx..
