61 - 80 of 204 Posts
Yaamon said:
By the way he said that they were still trying/working to fix the upconverted sd to hd quality with Central Pbs.
If you were talking to Joe about this, I'm surprised he still references upconverted programming in his conversation with you.
He said the same thing to me weeks ago when we all noticed the major problems with PBS. The thing is, the PQ issues are also on True HD programming - I sent him photos of both HD and upconverts.
Perhaps he feels that if the one is corrected, so will the other...
I'm moving this to the WNED thread.
Banned
I think the problem now is the main feed from PBS.
This morning I compared the signal from Rochester to Buffalo and they both exhibit a smear type image on moving scenes.
The picture from Pbs looks like they are using too much noise reduction or compressing the signal too much.
I remember when Start Choice was getting off the ground I had a friend that was in charge of the uplink and setup, he invited me into the trailer on Unwin Ave.
He was explaining and showing me the feed coming in and when you compress the signal what it does to the signal. I could clearly see when he added more compression you would get that smear type image on moving scenes. It's like the cheaper lcd tv when you watch sports or hockey. With more compression you also lost contrast and resolution too.
I noticed that the Buffalo feed was a few second ahead of the Rochester signal this way I could switch back and forth and compared the difference.
Wonder why the delay ?
The Rochester was amlost pilexating at times on moving scenes and the signal strength was very strong.
Banned
A bit of explaination of the problems we are viewing.
Spoke to Pbs this morning and he welcomed the feed back. I found out a bit more info that may explain most of the problems we are seeing.
I explain on most of the programming we are currently still seeing a bit of ghosting/smearing/Jello head even on the true HD shows and not just on the sd converted ones.
He explained that the flaws in the HD programs that we are seeing like the smearing/blur is not from his broadcasting/encoder side and most of it originates from the film source itself after conversion.
Here are some of the reasons he mentioned. First he said some of the show producers like to film in the 1280x720p 24fps format. He mentioned that the film rate of 24fps is not fast enough for tv. Then you have to convert from 24fps to 30fps and to 1920x1080i. Second some of the producers likes to film with the camera iris wide open, and this also tends to soften the picture losing detail/resolution.
He also mentioned that some of the producers also try and add filters to spice up and also reduce the detail when shooting in HD. He disagrees and commented, this is HD people wants to view the full resolution lets show all the detail it can. He prefers if a show originates from a 1920x1080i format in all its glory.
The sd to hd conversion is done at Pbs central (head office). He said Pbs Central are aware of the problems and is looking on how to try and correct/solve/improve the picture quality.
So it seems what we are seeing is a by product/negative of these conversions. He is only one station in hundreds so not sure if his voice will be heard.
Also when Pns(WNED) broadcast a film that was filmed in HD, (this can be in a 720p/24 fps or 1080i/30fps)(29.97fps to be exact), the HD logo will show on the upper left of your tv screen from WNED.. At 30fps it does minimize the problem.
This evening he mentioned from 4pm to 9pm the programs orginates in HD.
He mentioned the 8pm show tonight Window to the Sea, is a true HD 1920x1080i produced from Buffalo so there is no conversion done here. He asked if I would be able to watch and give a feed back.
I told him I would call him back tomorrow with the results of the 8pm show.
Ps: 57 I said one of our web moderators email him a few pictures of the problems a few weeks ago. He commented, if Iam not mistaken he thinks Joe had forward them onto Pbs central. He was not sure if he got back a response yet.
Discussion Starter #66
I'll have to clean my specs for this first :)
Thanks Yaamon... and 57 for the crusade.
Let's see the true picture tonight.
I was out today and just got back, so I couldn't judge. I can however say that some of PBS' comments don't make sense. A few months ago, we were privy to a lot of the same programming we are today. Examples include Smart Travels, Cousteau, etc.
A few months ago those programmes were pristine and of the highest quality with no ghosting/smearing/jello. Today they are crap.
His comments regarding "production values" or "conversions" therefore hold NO water when taking this into account. Something has changed in the last 2 months and it has nothing to do with production values or frame rate.
Discussion Starter #68
I still noticed minimal 'ghosting' during this broadcast, probably reduced due to the fact that there was not a lot of fast movement in the show.
I have also observed some pixelating during slow scene transitions on most shows.
Banned
filper I did notice a little smear on the faces of some of the people but the picture was much better than what we have been previously viewing.
No smear on Csi NY :) lastnight.
Fred from Pbs mentioned said this show was filmed in 1920x1080i/29.97fps, there was no conversion done or should I say a min amount?
Speaking to Fred this morning I did let him know on what we saw. I said the picture looks like you are running a digital noise reduction or too much compression.
He also had a coworker tape it and they can see the problems we are talking about now.
56 how did you know :) By the way I asked Fred what bit rate are you running on the HD channel and he said because of the think bright and the other sd between 11-13mps.
No wonder why we are seeing a reduction in quality. I asked him what was the bit rate previously and he said it has always been the same no changes?
I’m thinking even though the hd channels might have priority it needs a bit more bandwidth up to say 15mps to help solve the problems we are seeing.
Here the good news. He mentioned WNED was one of the first stations in the Buffalo area to broadcast in HD, so they have a first generation HD encoder. A new one he said cost over $100,000.us
The good news is that WNED has raised some $$ through viewers contribution and he expect to purchase a new encoder within 3 to 6 months and hope to have it operational in 6 months time.
This latest/newest encoder is two generations newer than what they are currently using, forgot if that means this is a 4th gen encoder.
Discussion Starter #70
Perhaps WNED could allocate ALL of the bandwidth to the HD channel for one specified hour during the evening as a test... and post the time/show in advance in this thread for us to compare.
Does anyone know if the folks at WNED are following this thread ? I sent them a link.
Banned
filper what I suggested was since the other two sub channels are sd why not reduce the bandwidth on them a little more to get a reasonable 15mps for the HD channel.
He said it was already at max compression they could do with further quality loss. :( Oh noo..
I watched the shows (OTA) with a more critical eye, European Travels, Smart Travels and Windows to the Sea. Though there might have been an improvement, there was still smearing in faster transitions, especially in "Windows".
Yaamon said:
Speaking to Fred this morning I did let him know on what we saw. I said the picture looks like you are running a digital noise reduction or too much compression.I’m thinking even though the hd channels might have priority it needs a bit more bandwidth up to say 15mps to help solve the problems we are seeing.
Bandwidth is quickly becoming the number one shortfall and the costs are escalating. You see it with Satellite, web (podcasting) and compression must be done right. PBS is probably being sucked into the bandwidth economy but they have gone too far.
Anyone heard anything of these issues lately? I watched the Yanni concert last night and the ghosting is still very apparent, especially on fast moving frames.
Banned
I think its not only the compression from Buffalo transmission but the signal feed that they are receiving this just adds to the poor picture quality.
I compared the feed to Rochester and while switching back and forth its the same crappy/poor picture quality on both Pbs stations.
I used to enjoy watching pbs now I hardly watch it. I think more board member here should be emailing or calling Pbs to voice the poor picture quality they are seeing. :mad:
If nobody calls and emails then they will think the few people have called they can live with it.
Call and speak to Fred I gave up as he did say they are waiting on a new encoder. But the picture was never like this before so it must be the feed they are receiving that just adds to the compression. They need more bandwidth atleast 15mps.
When I spoke to him about by 1280x1080i he flipped the switch back the same evening to 1920x1080i.
email to PBS
I just sent this email to PBS HQ, [email protected].
Hi,
I watch & enjoy your WNED Buffalo PBS HD programs through Rogers cable in Toronto Canada. For a while now there has been a problem with bad ghosting on panned shots. I have emailed WNED twice but got no response. Can you tell me if you know about this problem & what is being done about it.
Thanks, XXXXX
Looks like that link is not working
As previously mentioned in this thread, WNED have contacted PBS central about the issue and advised us that it will "take some time" for PBS Central to correct the problem. I'll let it go a few more weeks and recontact WNED with whatever news there is at the time.
It would be good for people to send e-mails to PBS Central, if there is proper e-mail address...
WNED may ignore e-mails for now since it's beyond their control.
Banned
57 the funny thing is that if WNED said they did not change anything different in transmission then what did PBS central do or did to affect the picture quality so much.
It's really so sad that the picture quality of Pbs has fallen down so bed. :(
I hardly ever watch it now.
