1 - 4 of 4 Posts
Hi,
I bought a Plasma Viera TCP50VT25. Approximatively 2 weeks after receiving it, I connected it to the internet to make a firmware upgrade (version 3.00). The upgrade works properly. But now I have "tick" (sound) coming out from behind TV and I'm getting them although the sound is turned off (level 0). So it is really a piece of the TV set not the sound.
Panasonic installed 30 pieces of foam to correct the probleme but it didn't work. Noises are allways there.
Anyone got this problem ?
Thanks.
Premium Member
Must have been a Gremlin. They do like to come and go in electronic stuff!!!
Seriously, if it was just a tick here and there then it might have been the TV boards expanding. My SONY in the bedroom does it all the time. As it heats up, you would think it's alive....or full of Gremlins!!! :)
1 - 4 of 4 Posts
