1 - 3 of 3 Posts
I'm trying to decide between two TV's for my living room. Currently we have a massive 27 inch CRT in there (massive in the sense that it is huge front to-back, and has big speakers on the sides). The minimum distance someone will be sitting from the TV is 7 feet, and the maximum is probably around 10 feet. I figure that 26 inches is too small for the room and 40 inches is probably too big.
The two TVs that I am looking at are a Sony Bravia KDL-32EX500 and a Panasonic L37U22. The prices are similar, both have 1080p and 120 HZ. I really don't know which I would be more satisfied with. On one hand, the Panasonic is bigger, on the other, I trust Sony more as a brand.
Any suggestions or comments would be much appreciated! Thanks in advance.
In my opinion for HD flat panels your size estimates of what you will find comfortable is a lot bigger than what you find comfortable in an old CRT SDTV. I'd say you could put a 50" or larger HDTV in your room. Having said that the Panasonic is a good brand, so I'd go for the bigger TV.
1 - 3 of 3 Posts
