1 - 6 of 6 Posts
I'm facing this problem since yesterday.
I have a Panasonic Smart TV, but now, when I press the OK button to start playback on a video, the video won't play.
There's nothing wrong with the remote nor with the OK button itself, because:
In the Youtube app, I can move around with arrows
In Netflix or Tunein or other apps in the tv, the OK button will work fine and start playback.
It is only on the Youtube app, that the OK button won't work, if in Youtube I go to search (for a video) I can move the cursor from letter to letter I select a letter to enter so I press the OK button, but it won't enter the letter.
I hava a Phillips Smart tv, and nothing is wrong with the Youtube app, it will play videos. fine.
Is anybody with a Panasonic Smart TV, facing this same problem of videos not playing?
Try unplugging the TV for 15 sec and taking the batteries out of the remote for 15 sec. If not replaced recently, new batteries in the remote would be a good idea as well.
I have a Panasonic Plasma ST60 smart tv.
Youtube isn't working. It loads, freezes and goes black. The return button does nothing - I have to press the "apps" button and start over with the same results.
I bought a WDTV Live some years ago that has a youtube aoo. Google blocked it within a couplr of months apparently because they couldn't show ads on it. I think it came back in SD only so I didn't use it.
I have a DOD dashcam that uses Google maps to show the route on the PC player. Google changed the api so it no longer works. The DOD tech dept was away from his desk when I called them and they didn't answer my email. I won't be buying another product from them.
So I tried the Panasonic dlna app and watched Fleetwood Mack "Tusk" with the USC Tojans marching band that I had previously downloaded from youtube with the Firefox extension. It downloads big files in seconds and you can move on to the next and store them.
Then I checked the Panasonic's SD card and usb stick and they all worked fine.
The year the TV was made is important. Apps get updated frequently and protocols get updated occasionally. Smart TVs are not always updated automatically. A 2 or 3 year old TV with a vendor specific interface is likely to lose support and not get updates either. That means the apps will eventually stop working due to protocol changes. TVs that use Android, Chromecast or Roku for the smart interface are more likely to have long term support. Even with those, support for specific hardware or software versions will stop eventually.
1 - 6 of 6 Posts
