My AE 100 has stopped working after about 3400 hours. The unit powers on and everything appears to be fine for about 60 seconds (including the lamp) then it shuts itself off with the lamp light blinking. This is not caused by the lamp timer -- I reset it to zero to be sure.
I would not mind just replacing the lamp if I was sure this would fix the problem. My concern is that the lap actually appears to work fine (at least for 60 seconds) so that replacing the lamp might not do any good. At about $350 for the lamp it is a bit of an expensive experiment.
Any advice or alternately, anyone have a used AE300 they would like to sell me for about the price of a bulb? (Much more than that and I figure I am better to go to a new Infocus 4805 of even AE700.
