1 - 3 of 3 Posts
I recently connecte an HDMI cable between my 8300HD box and my TV set, and the picture is indeed very good, although I'm not sure if it is appreciably better than it was with component (RGB) cables.
My question is this: with the HDMI cable connected to the TV, I would like to connect another output to my VCR (not that I plan to use the VCR as the PVR works great). Will the other outputs on the 8300HD still function with the HDMI cable installed?
1 - 3 of 3 Posts
