I have an old 30" LCD, I'm not currently using.
I just put a new hot tub on the deck out back,
& would like to be able to enjoy watching TV
while having a beverage and soaking.
My idea is to build a water-tight clear acrylic box around
the unit, but I would image heat build up will be an issue.
Is there a membrane that will allow air to flow but not moisture.
Ideally I'll use to small computer fans one in & one out with the
"magical" membrane.
The whole unit will be mounted on the wall of the sun room about
eight feet from the tub.
Do you think this might work?
And one other question I have... "Is there a universal water-proof remote available anywhere"
Thanks for your time.
"magical" membrane.
