weblurker said:
Which Toronto dealer did you end up buying the CM4228 from and how much did it cost?
If I lived near Ottawa and I wasn't so anxious. I'd have take TigerBangs up on his offer.
However I picked mine up from Hosick on Jane St. for $119 as they had one in stock and it was within a close driving distance for me. Originally they wanted $149, but I quoted them the neutron electronics of $110. FYI their location is not the easiest to find off Jane. I had to circle around the block once I passed it.
The following are other sources I tried:
Andrews Antenna in Unbridge and they carried the CM4228 for $120. They do installations as well.
Based on a search of dealers from the Channel Master site, I found a list of Ontario distributors which included Barret Xplore, Neutron Electronics, Trenton Distributors, and Western Equipment Limited (of Chatham)
When I called Barret they said they didn't carry the Channel Master 4228, but they referred me to V&E Antenna and suggested I speak to Eric. Eric said he could get the antenna from his Distributor if required. They also do installations as well.
Nutech Electronics out of Hamilton and St.Catherines also carries the Delhi 4 and 8 Bow tie antennas 1-800-263-8620
As well I found a wider geographical listing of dealers from Wade-Antenna's web site of dealers across Canada that carried the Delhi antenna and I would guess other OTA products as they listed a few of the same dealers noted above.
As for my results with the CM4228.......SUPER. I have a rotator on as well, but for the most part I could done without it from Brampton. As the weather gets better, I hope to get a little more height on the antenna, as I am just barely clearing my roof line.
