Taking down an old antenna
Hello,
a friend asked me to help him take down a damaged antenna from his newly purchased house. I was able to scope it out last weekend and this is what I could see (photo below):
- Antenna dates to the 80s, unsure of make
- There is a rotor
- Not sure this was a professional installation
- Antenna and rotor is non-functional inside the house, most likely due to cabling
- Antenna reflectors do not appear bent, they have unfolded out of their deployed position
- The mast is in a sort of metal footing that is bolted to the roof
- Mast was originally held by 4 guy wires. 2 of the guy wires are broken
- The whole things moves significantly when there is wind. The footing has started to tear out of the roof and is causing damage to the shingles.
We're thinking if we both go on the roof, if one of us holds the antenna mast steady and the other loosens the base we can break it free, then slowly lower the mast and antenna onto the roof together. With it lying down on the roof, we cut the last two guy wires and take it apart to get it off the roof.
Any better recommendations to take this thing down safely? Thanks in advance.
