Hi all
I've been having some issues with the video feed on my Xbox 360 that plays my Optik TV. Randomly, the feed (video and audio) will become extremely choppy and will sometimes freeze completely for several seconds at a time. This appears to be completely random and doesn't appear to happen in any type of pattern.
I've checked the same channels at the same time on my PVR which has no issues. I called Telus service with negative results. They had me reset everything including the xbox, pvr and modem. The also reset some things on their end which worked until the time I hung up with them.
The Modem is in a separate room and the Xbox is connected through the coax which is through the wall direct to where it is converted to Ethernet just prior to being connected to the xbox.
Does anyone know what my problem is? before I start buying new cabling or signal amplifiers for the coax.
