1 - 8 of 8 Posts
Just the other day we switched from Shaw to Telus Optik and we noticed that tv shows are blurry compared to Shaw's. We don't have HD content in either Shaw or Telus.
The TV is a Samsung HDTV 1080p currently set to 16:9. We tried setting Telus' STB (connected through HDMI) to 4:3, Standard wide, 720p, 1080i and so far all of them are blurry. In fact, only 4:3 shows full screen while all the others causes the shows to have huge "margins" on the left and right side. I expected at least 720p to work but it doesn't.
Any ideas on how to fix this? Sorry if I'm using possibly vague or wrong terms, I'm not very good when it comes to A/V equipment.
If you don't have HD, 720p or 1080i won't work as they are HD settings. I suggest that if you invested on a HDTV why not get HD service. It's a huge improvement. All we watch is HD unless my kids watch the kids SD channels. I agree though Telus SD material is slightly more blurry than shaw's analog service but the same in shaw digital SD service. Don't ask me why but a lot of people have noticed that aswell. It also depends on what kind of HDTV you have and size. The larger the tv, the blurrier you will see SD. HD always looks awesome.
he has an hd tv...
I would suggest you set the receiver to 720p
you can change aspect ratios by pressing the enter(options) button at the bottum of the remote. (my suggestion is to leave it on stretch, optik handles this MUCH better than bell does (where i had to keep on switching back and forth))
check the settings on your tv.. are you using a stretch or zoom mode of some kind? having 4:3 fill your whole screen seems a little strange to me.. see if you can find a pixel by pixel or tru mode or something of the like.. it's not going to clear up a bad picture but it will give you a representation of the correct aspect ratio coming from the stb and you can work from there.
Please also see the following post on Black Bars.
http://www.digitalhome.ca/forum/showthread.php?t=76089
The following post on WS stretch modes:
http://www.digitalhome.ca/forum/showthread.php?t=76074
And the following post useful for those new to the forum - FAQs, Search Tips, Optimization, etc.
SD channels should be 4:3 (with black bars on a 16:9 TV), unless you stretch them, which will cause them to be less clear and distorted. True HD programming should fill the 16:9 screen properly, with a logo usually appearing at the bottom right. Any stretching of SD or HD material will cause distortion and poorer PQ.
1 - 8 of 8 Posts
