1 - 3 of 3 Posts
One dish 2 double head LBS 4 cables . Flipped heads and cross wired and tested receivers all OK. Is it possible that one of the double heads is out of alinment. I get some of the channels but not all
do a check switch so we know what you have, list your signal strengths on the transponders for sat 91/82. What channels are missing?
what do you mean by "cross wired" do you know what you have for a switch/switches?
and yes it is possible your dish is slightly out of alignment.
1 - 3 of 3 Posts
