Hello gang, hoping you can help me out with this annoying difficult problem.
I use a Bluetooth keyboard when I type things on my tablet. Everything was working great a normal when all of a sudden it wasn’t
I mostly use the Bluetooth keyboard when I use Excel on my tablet. When I’m typing text inside a cell and press enter or move the arrow to the next cell, the onscreen keyboard keeps popping up. I have to press the arrow back button on the bottom of my screen to get rid of the on screen keyboard, but when I proceed to type something in the next cell then press enter or an arrow key to finish the entry the keyboard keeps popping back up
When researching a solution on-line the common solution is for me to disable the onscreen keyboard in the settings app. I did this but It didn’t work. Still have the same issues.
A temporary solution I found was there was a button on the bottom left of the keyboard screen that I pressed. I switched over from English (Canada) gboard to google voice typing
This solved the problem temporarily when using the keyboard. But the moment I started using my Bluetooth mouse to cut and paste within the spreadsheet. the problem came back
I also notice on my excel sheet that when I start typing in a cell the bottom of my screen changes from white to black
I’ve tried rebooting the tablet, uninstalling and reinstalling the app, even did a factory reset, but nothing worked
Something is over riding the Bluetooth and I don’t know what it is or how to solve the problem. Advice/help would be appreciated if possible, thanks
