41 - 60 of 2352 Posts
I'm w/ you, canadiangg. I'm more interested in getting U.S. stations than anything else. I'm not terribly interested in putting up an external antenna if not necessary.
It sucks that no A-Channel London DT has been announced to my knowledge. So to think of HDTV is just crazy talk! :p I think the 2011 cut off date is mighty generous of the CRTC. Yeah, I know we're not the U.S. and it's a different market here, but the private networks and their owners seem to be raking in the dough. And you gotta spend money to make money.
London, ON
New member. I like the forum a lot so far. Been reading about this whole OTA/FTA to get HD channels..
I got this Philips antenna to test things out. http://www.consumer.philips.com/consumer/en/ca/consumer/cc/_productid_SDV2510_27_CA_CONSUMER/TV-antenna+SDV2510-27
I've done three scans with no luck in getting a digital channel... www.antennaweb.org doesnt help too much as it only accepts U.S address's.
Anyone in London, ON picking up digital channels with an indoor antenna and if so what direction are you pointing it at?
Thanks!
Someone correct me if I'm wrong but I don't think there is any digital OTA in London at the moment.
There is a discussion elsewhere about SunTV having a digital presence throughout most of Ontario at some point in the future but not yet.
FTA_FTW: not digital (don't have a digital tuner) but like many folks I'm using an outdoor antenna indoors in london (I've got the 8 bay Channel Master 4228, some use the 4 bay 4221 some use the wineguard equivalent) and I get sarnia channels (CTV 42, Global 29) and City (31, woodstock maybe) from a 5th floor apartment facing wnw, along with Michigan stations part of the time (CBS 62, PBS 56, urban TV 38, ABC 7)
To the upper right in the blue navbar is the Search This Thread tool, and if you use the term "London" you will see all the posts in this thread from there, and you'll get a great perspective on digital TV in the Forest City. :)
OTA signals in London?
I just got my Sony KDL32L4000 and would like to receive OTA signals in London,Ontario...
I have "Turned-Off" the "Cable - On/Off" in the TV menu to enable the TV to receive "Antenna Signals",and hooked-up a simple dipole antenna to the input of the TV (Coax Connetor).
Then I did a search on my TV for Analog & Digital Channels...
A few channels did come up on the search as I recall, But, the reception was very poor...
Do I need a better signal source (Antenna) to get OTA in the City Of London, or is London to congested to get anything decent...???
Or is my "DIY" dipole antenna not going to do the job...???
Thanks for any suggestions or help...
*Hooking-Up the dipole, was only a very
temporary way for me to see if any signals were available*
Banned
Forgetaboutit. Digital OTA is virtually non-existent in London. If you are on the outskirts (i.e. south, east or west of the city proper) and don't mind investing a few $thousands in a 60'-80' tower, you might be able to pick up a few stations consistently.
Banned
I have never been able to pick up Erie radio stations in the city. It's possible to pick them up by driving 30 minutes SE though. Not even Rogers cable gets clear signals from Erie. :confused: I don't think the Erie ATSC stations are up to full power yet either. London is basically in a valley with a dividing hilltop at the south extremity. A very tall tower is required to see over that hill and city bylaws prohibit tall TV antenna towers. Despite their proximity, reception of US stations is pretty much limited to skip during warm weather. This is compounded by the abundance of stations sharing the same frequency in equidistant markets in Toronto, NY, PA, OH and MI. Then there are a number of Canadian repeater stations on adjacent frequencies. It makes reception in London almost impossible for most stations. OTOH, drive 30 minutes in any direction and US signals start popping up. Go figure. It's no accident that the first cable company was started in London and cable had a 95% penetration rate as early as the 1960s. London is truly the armpit of Southern Ontario. :eek:
Grand Bend HDTV?
A relative of mine is thinking about getting an HDTV in Grand Bend, but now the question is how to get an HD signal. Currently, they are on the cable provided through Southcott Pines, but I don't think they have an HD service. So I guess that leaves OTA or going with a satellite provider?!?
I think OTA might require a sizable tower to a) get over the trees and b) get the distant signals from Detroit, so maybe I should dissuade them on OTA if they aren't comfortable with this setup??
On the other hand, the property isn't used much outside of the summer months and paying for satellite 12 months a year might not be too palatable either?
Any thoughts on what I should recommend to them? Thanks!!
My family used to have a cottage not too far from Southcott Pines.
A 50 to 60ft tower is required to get reliable reception of Michigan UHF channels.
All the Michigan HD channels will be on UHF after next years' analog shutdown (except Fox 2 Detroit which will be on ch 7). There are NO Canadian HD channels.
Another option is the Star Choice 2nd residence program with satellite at home and at the cottage.
Getting Detroit stations from Grand Bend is going to be quite a stretch even with a good portion of the signal travelling over water (Lakes St. Clair and Huron). A high tower is a must as is a pre-amp. The cost won't be cheap.
Satellite might just be the best solution (either Star Choice or ExpressVu).
Having camped at Pinery park several summers and would agree that a deep fringe set-up would be required.There are 100 ft sand hills along the park and if you are behind this ridge then you could have a problem.If the antenna can see the water then it should be work.Driving around the area I seen many CM 4248 yagi pointing toward the U.S.I received alot of Michican FM at the Pinery Park but Detriot FM would fade sometimes.Check car reception at location for Detriot FM 101.1 and 104.3 seem strongest.Port Huron is alot closer but I am not sure if they have any TV Tx just FM.
London: HDTV Tuner?
Hey guys, I just joined these forums to ask you guys a question.
I'm getting a computer soon and I am wondering if it's worth it having an HDTV tuner built in.
I live in London and I never had a TV tuner before (I use Dish Network) but I think it's really nice to be able to watch something quick or leave it in the background while working, is there enough channels on the air in London to keep my interest?
I've been hearing it's "non existent" and using just a small Laptop Tuner, I think it would be pretty hard to get any sort of signal!
I'm getting the D7t series with the "hp integrated hdtv hybrid tuner"
Thanks in Advance!
Re: HDTV Tuner
I suppose it would all depend if it had a antenna built in or what kind of one you would have hooked up.
In terms of getting anything Digital/HD (ATSC) here in London we have one OTA station now, Sun TV on Channel 19.
If your tuner picks up (it should) Analogue (NTSC) channels then you will likely get "A", Omni 1&2, CBC, SRC, CTS and if your lucky CITY, Global, CTV and E! since they don't have their towers in London and once again it all depends on the antenna. I'm east of London and just use simple rabbit ears. I get all of those except Global.
Also, here in Canada all broadcasts are going to have to be in Digital/HD (ATSC) by sometime in 2011. Based on current trends don't except many channels in our area to launch in Digital/HD until right before the cutoff.
Hmm, so in about 3 years i'll start to really take advantage of the T.V tuner... I think I'll pass for now.
Thanks for the reply!
can you get any HD channels in London, ont? Say from Toronto, Windsor or Detroit? If so, would a regular bunny ear or cheap radio shack antenna work? I have an HDTV with a ATSC turner built in.
I think only one right now, but if you put the word "London" into the Search this Thread tool to the upper right you'll see all the London posts in this thread. :)
London is over 100 miles from Southfield, where the Detroit towers are. Windsor does not have any digital stations.
Sorry, but you'll have to look elsewhere.
That's great - anyone here from London getting it too? I would think with that signal level in St. Thomas it would be a sure thing in London! :)
