1 - 6 of 6 Posts
Hey,
My work has just started converting over to Office 2007 and I was thinking of getting the Home/Student package but find it is not easy to uh, well, find.
BB and FS only have 2010 while Tiger Direct only sells the 2007 licence.
I was interested in the 3install software package.
Does anyone know where in Toronto I could walk into a store and buy this?
Craig
· Member #1
Doubt you'll find it at retails nowadays. Maybe a small computer shop could order it for you.
Not sure why you want 2007 but files are compatible between versions.
If your Office is just converting to 2007, see if they have the Discs, then buy the Licence from Tiger. That should work.
Microsoft used to let employees install copies at home. At least a lot of oil companies in Alberta had the arrangement. I believe it was quite common!
Option B. If you have a student in the family look into the student deal.
1 - 6 of 6 Posts
