1 - 6 of 6 Posts
I have 2 different 9241 PVRs hooked up to my multi-switch. I get all my non-HD channels (satellite 91, right?), but only get some of the HD channels (satellite 82, right?) that I should be receiving. I'm confused because when I test my switch it says satellite 91 is working fine (as expected), but 82 isn't getting a satellite feed through. I'm getting some HD channels, though. If the feed isn't getting through shouldn't I not be getting any HD channels? Any thoughts as to what I should do to fix my problem would greatly appreciated? I could start flipping around cables, but I don't want to create a bigger mess. Which ports to the dish are for satellite 82 and which are for 91?
There is no standard way to connect the LNBF's to the SW44 but most people use inputs 1a & 1b for 91 and 2a & 2b for 82.
On the point Dish screen (Menu 6, 1, 1) which transponders are you missing on 82.?
Check the Power Inserter as well, the plug is small and not the best design.
I also realized that the new added HD channels are not showing
on the channel list. I checked all the transponders and they are all over 80%.
1 - 6 of 6 Posts
