Status
Not open for further replies.
1 - 8 of 8 Posts
Hello all,
I'm new here and have read through the stickies and done many searches for current DVR options for OTA Antenna reception. I have only found 2 options that meet my requirements (Guide, Hard Drive, single or dual tuner, dual preferred, scheduled recording, not a HTPC).
The two I have found are the Channel Master CM-7000 and the Tivo system. I don't like the Tivo due to the monthly sub. Are there any other options / recommendations?
I am getting a Channel Master CM4228HD and amplifier as requred (not researched yet). I live in Chatham Ontario (North west corner of town) and have a Sharp Aquos TV with internal NTSC/ATSC/QAM tuners. I have a TV Fool report but can't post it.
Thanks for any insight you may provide.
.... I have only found 2 options that meet my requirements (Guide, Hard Drive, single or dual tuner, dual preferred, scheduled recording, not a HTPC).
I concur with your observation and needs, as the last thing I wanted to do was give more control over to a proven troublesome product like Windoze, and which proves that in a quick start in a limited market combined with slick marketing of a second rate product, gave rise to the term, 'you can fool most of the people some of the time'. Don't get me started on cable/satellite.
Since you also stated you don't want TIVO, the only options remaining with something with a HDD are the CM7000PAL (records in HD) or the Magnavox MDR515H (records in SD with automatic upconversion). Check out this link on the site for more info. http://www.digitalhome.ca/forum/showthread.php?t=56806&page=16
Discussion Starter · #7 ·
FTA Satellite Box
OK, the last post didn't show up because of a link (I'm guessing).
I am going to try a FTA satellite receiver that has an ATSC tuner and see what happens. I have an older one that isn't HD but has the PVR function via USB.
The one that I'm looking at if it works is the Sonicview SV 8000HD for $260 (about $100 cheaper than the Channel Master)
I will post my finding.
1 - 8 of 8 Posts
Status
