1 - 20 of 24 Posts
Have you ever noticed when placing a long distance call you don't get the prompt anymore that says "your call is being connected; long distance charges will apply."?
Well, I opened my daughters bill and guess what? Over $100 in long distance charges. When I asked my daughter about the calls; she says, "I didn't get the warning prompt, so how am I supposed know?" Can't blame my daughter for that response so I decided to try for myself and she was right.
So I called Bell and was told this was removed back in November 2014; I'm like, what, really, how can you do this without telling anyone? The rep couldn't even tell me why this removed! This is negative optioning in my opinion, can Bell do this to people??? Does the CRTC even know??? I'm so angry!!!
Can anyone help shed some light on this and can anything be done to bring this back?
The bigger controversy here, in my opinion, is that the concept of "long distance" still exists at all. But that's an entirely different discussion.
Discussion Starter #5
Does she have a "1" included at the start of phone numbers in her contacts?
My daughter has a smartphone whereby you don't even have to include the 1+ any more. I tested this theory and the call connected without the prompt. Anyways, I checked her contacts list and they are all ten digit numbers....
Thanks for the heads up.
This does not affect me but I am willing to bet my parents will get caught. I will let them know. They live in a rural district and what is long distance and what is not is not always clear before calling. That is calls originating from one location are local but the other direction are long distance.
I know there is a place (my googlefu has failed me) where you can check exchanges and see which ones are long distance. With LNP that may become more complicated.
Without knowing what the local calling boundaries are, how is this fair to one that doesn't know the difference between what's local and what's long distance?? Like my daughter and your parents...huh!
I know there is a place (my googlefu has failed me) where you can check exchanges and see which ones are logn distance. With LNP that may become more complicated.
I may be wrong here, but don't some local calling areas vary by carrier?! I recall a few years ago, for example, that Rogers decided to shrink the Toronto local calling area.
Yes that is what I was thinking Jase. Nemnoch was a member here and used to post LCA and ELCA lists. I can't seem to find a valid link anymore.
It seems almost every plan has free long distance within Canada these days. I think unknown long distance charges will be less and less of an issue going forward.
It would take a long time for domestic long distance to be phased out, there are still a lot of grandfathered plans, and other phone carriers who still have long distance options, it would require EVERYBODY, EVERY CARRIER, and even resellers to force people to new plans which wont be easy, but its a start.
All long distance and roaming charges should be eliminated. It costs almost nothing for carriers to provide roaming and long distance with modern infrastructure yet they retain inflated charges in order to victimize customers that don't purchase expensive plans they don't need. Companies like Bell seem to think they are entitled to hundreds of dollars a month from every Canadian regardless of need, actual use or ability to pay. It's time to put an end to the "Bell tithe."
I'm on Rogers. I used to have to pay long distance on my home phone, but now I can dial toll free across Canada. What I'd appreciate would be if they stopped advising a call is local (in the GTA) and not to dial 1. Because of this, I have to dial again without the 1. This is an issue when I'm calling back someone who called me first and the call display number includes the 1. Instead of using display dial, I have to manually dial. On the other hand, my cell phonecalls ignore the 1, when not needed. All the numbers on my cell phone start with +1, which most cell carriers accept and works fine whether the call is local or not.
I also remember when it was long distance to call across Winston Churchill Blvd, from Oakville to Mississauga, but things have changed and it shouldn't be a big deal to change, even with grandfathered customers.
BTW, is Bell still charging for touch tone? They charged it for years after pulse dial lines were no longer available. Now there was a scam!
I used to have the +1 in front of all my numbers on my 9 year old flip phone. I have just started using an iPhone 5S and imported all my contacts from Outlook, where the +1 was not present. Do I need to add the +1 to all my numbers or is the phone (and the providers) now smart enough to know it's LD if I dial say (604) 555-5555? I'm with Rogers PAYGo, but I thought I'd post in this thread where the +1 was mentioned.
When I went to edit the numbers under contacts in my iPhone I couldn't even find the "+" sign, although I might have missed it...
the + is the international prefix (replaces 00 I believe) , on some phones you can hold down one of the keys on the bottom row to add special characters like +, P(ause), W(ait). on my Samsung Android, its the 0 key, but could be * (star/flower) or # (pound/hashtag) on other phones.
I do not have north america calling on my plan, only Canada wide long distance, so all my Canadian numbers have the 1-416-xxx-xxxx, but to avoid accidental LD to US, all my US numbers are just 716-xxx-xxxx with no 1 prefix so if i were to call it, I would probably get the recording the call is incomplete because I did not put the mandatory 1 for longdistance and I'm OKAY with this because I can use my calling card for the rare occasions I need to call USA.
On my iPhone 5S, holding the zero does nothing, however, there's a button to the left of zero that has a few symbols on it. Pressing it gets me to a new "page" where I have +, #, *, Pause, Wait.
1 - 20 of 24 Posts
