1 - 10 of 10 Posts
Does anyone else have this problem, every now and then (lets say every 2 weeks) I can't connect to the internet but yet i can still receive a tv signal good.
I reset the modem and unplug and plug the lan 1 connection , then the light on the modem turns red again, and i am good to go. Does anyone else experience this problem, should I call up and request help.
Banned
kinda just sounds like a bum modem, i have had Aliant internet for almost a year and have had to reboot my modem only once that i can remember. i would def try calling support can can remote you modem and check things out and worst comes to worst send you a new modem :)
I've had it happen myself, several coworkers have also had it happen at exactly the same time. It actually went down at about 9:30pm last night. It seems to be a Fredericton-wide problem as it happens on both sides of the river at the same time.
1 - 10 of 10 Posts
