Looking to get the ATSC 3.0 signal from Buffalo, what are the decent Next Gen boxes that can also decode the encrypted signals?
Yes. Zapperbox FAQs - Frequently Asked Questions About Products - ZapperBoxCurious if these external units can receive updates via an internet connection; like the recent NG TVs.
ADTH has a nextgen Tuner that might work for you as it has ATSC3 and drm solved. They are currently out of stock.
It is a poor performing device as most of it's development is done offshore. You get what you pay for. But don't take my word for it read the posts in this thread :ADTH has a nextgen Tuner that might work for you as it has ATSC3 and drm solved. They are currently out of stock.
Well, here is a year later. What did you decide to do?I am also looking for an ATSC 3.0 tuner, to connect to a Windows computer.
Any advice?
It looks like the USB sticks from GT and Xytec only work with Android, not Windows.
The ATSC 3.0 boxes from HDHR or Zapperbox could work, but I don't want to spend that much until they get the DRM/encryption nonsense worked out.
I can't find the ADTH devices available in Canada.
There are no 3.0 stations in my area yet (Kingston Ontario / Watertown NY) but I want to be future-proof for when that happens.
I already have a HDHR Connect (ATSC 1.0) but I would like another tuner for more reception options.
Maybe I will get a cheap-ish 1.0 USB stick for now, or bite the bullet and get a HDHR ATSC 3.0 and hope that they can update software to handle the DRM
And hope that they don't geo-block us in Canada :-( :-( :-(
