I bought a new Whalen tv stand (Portland 3 in 1) at costco. It has a high pole that you mount the tv on. There are 4 holes on the back of my LG tv. They tell me to use 2 short screws on the top and two longer screws on the bottom with a spacer added on the bottom. This causes the tv to stick out a bit at the bottom. I wonder why they want you to do this. It seems strange and a little unstable to me. I checked the instructions on line and I did it right. Is this maybe to shift the weight to the back?
Don
Don
