1 - 20 of 46 Posts
Hello,
I was hoping someone (Holl_ands? or Niklm) would post some antenna designs rescaled for the new UHF spectrum,
but I haven't seem any here.
Anyone know if Holl_ands is still active on this site?
I would really love to build a Fat Dipole antenna for the new UHF spectrum, I have lots of tubing lying around waiting to be used! :(
Schoolbus
Hi Schoolbus
Here's a design for a UHF antenna made from 1/2" copper tubing, soldered joints and a 1/4" bolt to separate the element from the reflector. Feed point is made by soldering in #10 copper screws, through holes in the copper elbow. I designed it to work well from 470mhz to 700mhz. Many of the parts are sized to make the antenna easy to build. Tubing lengths are sized so that they are cut to the nearest 1/2". Lengths in the NEC file are for the tubing and the joints, so lenghts might be effected by the brand of elbows and tees that you use. I've got a version that is made of 10 pieces of tubing cut 5" long, and 10 pieces cut to 8" that is almost as efficient. The design could be optimized a bit more, if you weren't concerned with keeping dimension easy to measure and cut. NEC file below.
Code:
CM
CE
SY Scale=1.0
SY sc=Scale
SY Rsrc=0.14	'SOURCE Wire Radius, Adjusted for AGT=1.0:    UHF=0.262    584=0.24   Autoseg(10)   UHF=0.143   584=0.14
SY Rquad=0.3125	'BiQuad Element Radius 1/2" copper
SY Ract=0.3125	'Reflector Element Radius
SY Rbolt=0.125	'Bolt Radius
SY Rwing=0.1		'Wing Radius     #10 bolt
SY feedgap=1.0	'Wing Feedpoint Gap Size    1.0
SY fgap=3.53539	'BiQuad Gap Size
SY fg=fgap/2		'1/2 feed gap
SY qlen=6.9375
SY qdelta=qlen*.7071
SY qfdelta=qdelta-fg
SY qflen=qfdelta*1.4142
SY qh=qfdelta+qdelta
SY rdback=4.25
SY rdb=rdback
SY Rlen1=19.375	'11.375     19.375
SY Rpos1=3.34375	'2.84375      3.34375
SY Rlen2=11.25	'11.25
SY Rpos2delta=4.8125	'4.8125
SY Rpos2=Rpos1+Rpos2delta
GW	1	1	rdb*sc	-feedgap/2*sc	0*sc	rdb*sc	feedgap/2*sc	0*sc	Rsrc
GW	2	2	rdb*sc	fg*sc	0*sc	rdb*sc	qdelta*sc	qfdelta*sc	Rquad
GW	3	2	rdb*sc	-fg*sc	0*sc	rdb*sc	-qdelta*sc	qfdelta*sc	Rquad
GW	4	2	rdb*sc	fg*sc	0*sc	rdb*sc	qdelta*sc	-qfdelta*sc	Rquad
GW	5	2	rdb*sc	-fg*sc	0*sc	rdb*sc	-qdelta*sc	-qfdelta*sc	Rquad
GW	6	3	rdb*sc	qdelta*sc	qfdelta*sc	rdb*sc	0*sc	qh*sc	Rquad
GW	7	3	rdb*sc	-qdelta*sc	qfdelta*sc	rdb*sc	0*sc	qh*sc	Rquad
GW	8	3	rdb*sc	qdelta*sc	-qfdelta*sc	rdb*sc	0*sc	-qh*sc	Rquad
GW	9	3	rdb*sc	-qdelta*sc	-qfdelta*sc	rdb*sc	0*sc	-qh*sc	Rquad
GW	12	2	rdb*sc	-fg*sc	0*sc	rdb*sc	-feedgap/2*sc	0*sc	Rwing
GW	13	2	rdb*sc	fg*sc	0*sc	rdb*sc	feedgap/2*sc	0*sc	Rwing
GW	51	3	0*sc	-Rlen1/2*sc	Rpos1*sc	0*sc	0*sc	Rpos1*sc	Ract
GW	52	3	0*sc	-Rlen1/2*sc	-Rpos1*sc	0*sc	0*sc	-Rpos1*sc	Ract
GW	51	3	0*sc	0*sc	Rpos1*sc	0*sc	Rlen1/2*sc	Rpos1*sc	Ract
GW	521	3	0*sc	0*sc	-Rpos1*sc	0*sc	Rlen1/2*sc	-Rpos1*sc	Ract
GW	531	3	0*sc	-Rlen2/2*sc	Rpos2*sc	0*sc	0*sc	Rpos2*sc	Ract
GW	54	3	0*sc	-Rlen2/2*sc	-Rpos2*sc	0*sc	0*sc	-Rpos2*sc	Ract
GW	531	3	0*sc	0*sc	Rpos2*sc	0*sc	Rlen2/2*sc	Rpos2*sc	Ract
GW	541	3	0*sc	0*sc	-Rpos2*sc	0*sc	Rlen2/2*sc	-Rpos2*sc	Ract
GW	55	2	0*sc	0*sc	-Rpos2*sc	0*sc	0*sc	-Rpos1*sc	Ract
GW	56	2	0*sc	0*sc	Rpos2*sc	0*sc	0*sc	Rpos1*sc	Ract
GW	57	3	0*sc	Rlen1/2*sc	-Rpos1*sc	0*sc	Rlen1/2*sc	Rpos1*sc	Ract
GW	58	3	0*sc	-Rlen1/2*sc	-Rpos1*sc	0*sc	-Rlen1/2*sc	Rpos1*sc	Ract
GW	61	3	0*sc	0*sc	Rpos2*sc	rdb*sc	0*sc	qh*sc	Rbolt
GW	62	3	0*sc	0*sc	-Rpos2*sc	rdb*sc	0*sc	-qh*sc	Rbolt
GS	0	0	0.0254
GE	0
LD	5	0	0	0	58000000	'Copper Elements
GN	-1
EK
EX	0	1	1	0	1	0	0
FR	0	40	0	0	470	6
RP	0	1	73	1510	90	0	1	5	0	0
EN
Let me know if you need more info or pictures.
Lawrence
Discussion Starter #3
Hello,
thx, my tubing is all 1 inch, which is why I was hoping to see a revised Fat Dipole antenna :(
Schoolbus
I don't have any personal information on the question, but the forum shows his "Last Activity: 2019-10-17 01:17 PM".
Holl_ands has posted some new spectrum designs on his imageevent page, but not the fat dipole. There was also a recent thread about a new spectrum GH antenna, but again, not fat dipole.
One could also use the scaling calculator at: Martin E. Meserve - K7MEM - Antenna Frequency/Diameter/Length Scaling to scale an older fat dipole design for use on the new spectrum. It would not be optimized, but it should be close enough.
Premium Member
The last activity by holl_ands on the other forum he uses, AVS, was on Oct 5, 2019. So, it's been almost two months since he was here on DHC, which is unusual. I wonder what happened to him? He is an expert antenna modeler.
Premium Member
Hello,
Schoolbus
What type of antenna did you want to make for UHF, a yagi or something like a 4-bay panel antenna like the M4 with fat tubing elements instead of whiskers? The 4-bay would have wider bandwidth than the yagi to cover 14-36 on UHF with more constant gain across the band. It would be similar to the Winegard HD-4400, but use tubing instead of wide strips.
https://imageevent.com/holl_ands/multibaydipoles/winegardhd4400
You would need to increase the element lengths and vertical bay spacing for 14-36.
http://www.hdtvprimer.com/ANTENNAS/comparing.html
http://www.hdtvprimer.com/ANTENNAS/w4400.html
Something like this 8-bay fat dipole is what comes to my mind. I have used it as a basis for scaling to fit the tube I have on hand and the channel I want to receive, but never got around to actually building.
Don't know what Holl_ands has been up to the last couple of months, but do remember reading that he has been teaching a grandson to run the antenna modeling software. Been wondering when/if we might hear from the grandson...
Discussion Starter #8
Neil, that 8 Bay Fat Dipole is what I am after, but scaled for the new UHF Spectrum.
I have a LOT of 1 inch stainsteel tubing!
Rabbit, the HD4400 antenna is in the same zone- but from what Holland modelled of those Wineguard antennas, they seem hi gain but very narrow focus. Which is why I like Hollands Fat Dipole Antennas, they are hi gain, but wider focus, which is what I need where I am located (Oshawa Ontario, trying to pick up but Toronto and Buffalo and Hamilton)
IF only Holland could redo his Fat Dipole antennas scaled for the new UHF Spectrum.
Schoolbus
Discussion Starter #9
The Dipole Antennas, do much better on the lower end of the UHF spectrum than the M4 style antennas, which is why I want to build one of those.
Schoolbus
@schoolbus,
Its quite simple to frequency scale any antenna from a higher freq to a lower freq.
Just increase all dimensions, including the wire radius by a frequency scale factor of old_freq/new_freq. A quick and dirty method would be to modify the existing model's scaling card (GS). For example in holl_ands 8 bay fat dipole, UHF Vert 8-Bay Dipole + 43 Pair RR - OPT
try changing this line. And see what ya come up with.
Code:
 from
GS 0 0 0.0254' CONVERT ABOVE FROM INCHES TO METERS FOR NEC.
Code:
to
GS 0 0 0.028275' CONVERT ABOVE FROM INCHES TO METERS FOR NEC.
In other words from .0254, to .0254 * 590 MHz/530 MHz (chosen rather arbitrarily looking at the existing model's freq sweep).
resulted in a very similar pattern, that rolls off much sooner and 15 dBi gain at 470 MHz, instead of 13.5 dBi gain in the original model.
The peak gain essentially unchanged, 16.75 dBi but occurred at 614 MHz, instead of 680 MHz. Without any further optimization.
Though the dipoles would be like an inch O.D., phasing lines like 1/8" O.D. and the reflectors like 3/8" O.D.
And around 67" tall...
Discussion Starter #11
That doesnt sound bad.
Would the lobe pattern be the same?
Could I do fencing instead of the RRods?
Schoolbus
here, in this quick hack, I multiplied all holl_ands' symbols that are used as inputs
by 590 MHz / 530 MHz.
Model
Sweep
Pattern
results
HTML:
         --- Gain ---              -- Ratios -- -- Impedance --
   Freq    Raw    Net   SWR BeamW    F/R    F/B    Real    Imag  AGT  corr
  467.0  15.16  15.14  1.15  40.9  14.77  30.22  285.09  -37.11 0.97 -0.14
  473.0  15.26  15.22  1.22  40.8  14.91  31.43  268.33  -46.14 0.97 -0.14
  479.0  15.35  15.28  1.29  40.7  15.14  32.78  251.65  -51.28 0.97 -0.14
  485.0  15.42  15.32  1.37  40.8  15.53  33.87  235.60  -52.93 0.97 -0.14
  491.0  15.49  15.35  1.44  40.8  15.82  34.63  221.04  -51.61 0.97 -0.14
  497.0  15.50  15.32  1.51  40.7  16.01  35.24  208.18  -48.12 0.98 -0.07
  503.0  15.56  15.34  1.58  40.8  16.28  35.73  197.14  -43.07 0.98 -0.07
  509.0  15.57  15.31  1.63  41.1  17.00  36.11  188.04  -36.98 0.98 -0.07
  515.0  15.61  15.31  1.70  40.7  17.38  34.24  179.06  -31.57 0.98 -0.07
  521.0  15.84  15.50  1.76  39.8  16.29  33.58  171.40  -21.92 0.98 -0.07
  527.0  15.89  15.52  1.80  39.5  16.28  33.18  166.64  -12.33 1.00 -0.01
  533.0  15.99  15.61  1.82  38.7  15.62  32.04  165.17   -2.19 1.00 -0.01
  539.0  16.07  15.64  1.88  39.7  15.86  32.93  159.48    2.64 1.00 -0.01
  545.0  16.16  15.71  1.91  40.1  16.91  32.34  157.61   15.86 1.00 -0.01
  551.0  16.17  15.72  1.91  40.9  17.67  32.50  158.99   29.00 1.00 -0.01
  557.0  16.23  15.78  1.91  39.9  18.26  30.45  160.82   38.08 1.01  0.05
  563.0  16.33  15.88  1.92  39.8  18.71  29.72  162.96   51.28 1.01  0.05
  569.0  16.57  16.17  1.85  38.7  16.89  29.14  173.72   65.19 1.01  0.05
  575.0  16.70  16.32  1.80  38.3  16.57  28.46  183.03   77.65 1.01  0.05
  581.0  16.77  16.43  1.76  39.0  17.64  27.93  196.67   92.20 1.01  0.05
  587.0  16.68  16.38  1.69  38.9  17.59  27.42  216.19  105.51 1.06  0.26
  593.0  16.77  16.52  1.61  38.7  17.59  26.72  244.14  117.00 1.06  0.26
  599.0  16.84  16.65  1.52  38.0  16.88  25.87  282.82  120.76 1.06  0.26
  605.0  16.83  16.68  1.45  38.5  17.39  25.38  332.97  112.27 1.06  0.26
  611.0  16.73  16.61  1.39  38.5  17.19  24.67  387.98   72.64 1.06  0.26
  617.0  15.95  15.83  1.40  38.6  16.87  23.88  420.89   -7.09 1.19  0.76
  623.0  15.42  15.26  1.48  39.0  16.31  23.03  395.07  -98.59 1.19  0.76
  629.0  14.51  14.27  1.61  40.0  15.49  22.08  322.90 -148.81 1.19  0.76
  635.0  13.14  12.81  1.75  44.2  14.42  21.03  252.35 -148.28 1.19  0.76
  641.0  11.25  10.86  1.84  88.7  13.01  19.88  206.25 -121.87 1.19  0.76
  647.0   9.10   8.69  1.86 102.3  11.33  18.65  182.79  -89.06 1.15  0.60
  653.0   6.70   6.33  1.80 109.8   9.59  17.55  175.35  -57.83 1.15  0.60
  659.0   4.99   4.69  1.70 110.8   8.52  17.20  179.55  -30.71 1.15  0.60
  665.0   4.74   4.53  1.56 104.1   8.75  18.12  192.90   -8.96 1.15  0.60
  671.0   5.56   5.44  1.40  93.2   9.87  19.67  214.24    5.70 1.15  0.60
  677.0   6.77   6.72  1.24  82.6  11.17  20.78  242.26    9.96 1.11  0.47
  683.0   7.73   7.72  1.10  74.3  12.28  21.20  273.30    0.04 1.11  0.47
  689.0   8.49   8.48  1.10  68.6  13.16  20.94  299.93  -27.71 1.11  0.47
  695.0   9.07   9.01  1.26  64.1  13.79  20.37  310.14  -70.52 1.11  0.47
  701.0   9.44   9.28  1.47  61.4  14.22  19.62  295.23 -115.54 1.11  0.47
Modified holl_ands' nec2 file to run thru nikiml's eval script...
HTML:
CM UHF 8-Bay Vertical Fat Dipoles, NO Sweep, 43-Pairs-RR, 4nec2 by holl_ands, 29Aug2014
CM Frequency scale to the post repack spectrum, 15Dec2019
CM 1-in O.D. Elements, 43 Reflector Rods 3/8-in O.D, Hop=1.1-in.  PYTHONSEG(6), 7 Python Variables.
CM DipoleLength=Vrbl, DipoleSpacing=Vrbl, FeedSep=Vrbl (AWG8).  Ignore Fat Wire Warnings.
CM
CM 911 Segs so can use default nec2dxs1k6 NEC-Engine, NO Errors or Warnings, UHF AGT=1.0.
'CMD--OPT -s(470,12,10) -t(16,18) --swr-target=2.7 --f2r-target=20 --f2b-target=20
'CMD--OPT --target-function=(4*max_ml+16*max_gain_diff+4*max_f2r_diff+max_f2b_diff)/25
'CMD--OPT --auto-segmentation=0 --char-impedance=300 --validate-geometry=0
CM D--EVAL --auto-segmentation=6 --char-impedance=300 --num-cores=8
CM D--EVAL  --uhf-52 --total-gain --centers --publish
CE
' Simulated SOURCE Wire Radius, Adjust for AGT=1.0: UHF=0.529
SY Freqscale=590/530
SY Rsrc=0.5520
SY Rdip=0.4375 * Freqscale
SY Rfeed=0.06425 * Freqscale
' Dipole-To-Dipole Separation:
SY DDSep=8.954643 * Freqscale' 7, 15
' Dipole Half-Length (cut down from BOUVAL's 9.75-in, may round to 1/8-inch):
SY DLen=7.859371 * Freqscale' 5, 12
SY DSwp=0
' Separation between two FEEDLINE wires:
SY FeedSep=2.165418 * Freqscale' 1, 6
' From center of Feedline Cross-Over to center of OUTER Dipoles:
SY ZCross=1.37709 * Freqscale' 1.375, 8.25
SY Hop=1 * Freqscale
SY Cond=2e+07
' Reflector Rod Separation behind Dipoles (may round to 1/8-in):
SY RS=4.75988 * Freqscale' 3, 25
' Reflector Rod-to-Rod Separation (may round to 1/8-in):
SY RR=1.502842 * Freqscale' 1.5, 3
' Reflector Rod Half-Lengths (may round to 1/8-in):
SY YRod=16.78125 * Freqscale' 10, 30
SY Rrod=0.1875 * Freqscale
' Gap Between each Reflector Rod Pair:
SY Rgap=0.2504655 * Freqscale' 0.25, 25
' Calculated from above INPUT Values:
SY ZDInr=DDSep/2' Distance from antenna center to center of INNER Dipole
SY ZDMid=DDSep/2+DDSep' Distance from antenna center to center of LOWER-MIDDLE Dipole
SY Z1=ZDMid
SY Z2=ZDMid
SY Z3=ZDMid
SY Z4=ZDMid-ZCross+0.875
SY Z5=ZDMid-ZCross
SY Z6=ZDMid-ZCross-0.875
SY Z7=ZDInr
SY Z8=ZDInr
SY Z9=ZDInr
SY Z11=DDSep+ZDMid
SY Z12=DDSep+ZDMid
SY Z13=DDSep+ZDMid
SY Z14=DDSep+ZDMid-ZCross+0.875
SY Z15=DDSep+ZDMid-ZCross
SY Z16=DDSep+ZDMid-ZCross-0.875
SY Z17=DDSep+ZDInr
SY Z18=DDSep+ZDInr
SY Z19=DDSep+ZDInr
SY Z21=2*DDSep+ZDMid
SY Z22=2*DDSep+ZDMid
SY Z23=2*DDSep+ZDMid
SY Z24=2*DDSep+ZDMid-ZCross+0.875
SY Z25=2*DDSep+ZDMid-ZCross
SY Z26=2*DDSep+ZDMid-ZCross-0.875
SY Z27=2*DDSep+ZDInr
SY Z28=2*DDSep+ZDInr
SY Z29=2*DDSep+ZDInr
SY YDInr=FeedSep/2+(DLen^2-DSwp^2)^0.5' Ymax for Inner Dipoles
SY YDOut=FeedSep/2+(DLen^2-DSwp^2)^0.5' Ymax for Outer Dipoles
'  #    segs    X1      Y1        Z1     X2        Y2         Z2    radius
' SIMULATED SOURCE WIRE:
GW  1     1    +RS    -FeedSep/2    0.0     +RS        FeedSep/2     0.0    Rsrc
' INNER DIPOLES:
GW  2     5   DSwp+RS     YDInr         Z7     +RS        FeedSep/2     Z8    Rdip
GW  3     5    +RS    -FeedSep/2     Z8   DSwp+RS    -YDInr     Z7    Rdip
GW  4     5   DSwp+RS     YDInr        -Z7    +RS        FeedSep/2    -Z8    Rdip
GW  5     5    +RS    -FeedSep/2    -Z8   DSwp+RS    -YDInr    -Z7    Rdip
' LOWER-MIDDLE DIPOLES:
GW  6     5   DSwp+RS     YDOut         Z1      +RS        FeedSep/2     Z2    Rdip
GW  7     5    +RS    -FeedSep/2     Z2   DSwp+RS    -YDOut     Z1    Rdip
GW  8     5   DSwp+RS     YDOut        -Z1      +RS        FeedSep/2    -Z2    Rdip
GW  9     5    +RS    -FeedSep/2    -Z2   DSwp+RS    -YDOut    -Z1    Rdip
' OUTER-MIDDLE DIPOLES:
GW 10     5   DSwp+RS     YDOut         Z11     +RS        FeedSep/2     Z12    Rdip
GW 11     5    +RS    -FeedSep/2     Z12  DSwp+RS   -YDOut     Z11    Rdip
GW 12     5   DSwp+RS     YDOut        -Z11      +RS        FeedSep/2    -Z12    Rdip
GW 13     5    +RS    -FeedSep/2    -Z12  DSwp+RS   -YDOut    -Z11    Rdip
' OUTER DIPOLES:
GW 14     5   DSwp+RS     YDOut         Z21     +RS        FeedSep/2     Z22    Rdip
GW 15     5    +RS    -FeedSep/2     Z22  DSwp+RS   -YDOut     Z21    Rdip
GW 16     5   DSwp+RS     YDOut        -Z21      +RS        FeedSep/2    -Z22    Rdip
GW 17     5    +RS    -FeedSep/2    -Z22  DSwp+RS   -YDOut    -Z21    Rdip
' CENTER FEEDLINE:
GW 18     2    +RS     FeedSep/2     Z8     +RS        FeedSep/2     0.0    Rfeed
GW 19     2    +RS    -FeedSep/2     Z8     +RS       -FeedSep/2     0.0    Rfeed
GW 20     2    +RS     FeedSep/2    -Z8     +RS        FeedSep/2     0.0    Rfeed
GW 21     2     +RS    -FeedSep/2    -Z8     +RS       -FeedSep/2     0.0    Rfeed
' INNER CROSS-OVER FEEDLINE:
GW 22     1    +RS     FeedSep/2     Z2     +RS        FeedSep/2     Z4    Rfeed
GW 23     1    +RS    -FeedSep/2     Z2     +RS       -FeedSep/2     Z4    Rfeed
GW 24     4    +RS     FeedSep/2     Z6     +RS        FeedSep/2     Z8    Rfeed
GW 25     4    +RS    -FeedSep/2     Z6     +RS       -FeedSep/2     Z8    Rfeed
GW 26     1    +RS    -FeedSep/2     Z6   Hop/2+RS   0.0     Z5    Rfeed
GW 27     1    +RS     FeedSep/2     Z4   Hop/2+RS   0.0     Z5    Rfeed
GW 28     1    +RS     FeedSep/2     Z6  -Hop/2+RS   0.0     Z5    Rfeed
GW 29     1    +RS    -FeedSep/2     Z4  -Hop/2+RS   0.0     Z5    Rfeed
GW 30     1    +RS     FeedSep/2    -Z2     +RS        FeedSep/2    -Z4    Rfeed
GW 31     1    +RS    -FeedSep/2    -Z2     +RS       -FeedSep/2    -Z4    Rfeed
GW 32     4    +RS     FeedSep/2    -Z6     +RS        FeedSep/2    -Z8    Rfeed
GW 33     4    +RS    -FeedSep/2    -Z6     +RS       -FeedSep/2    -Z8    Rfeed
GW 34     1    +RS    -FeedSep/2    -Z6  -Hop/2+RS   0.0    -Z5    Rfeed
GW 35     1    +RS     FeedSep/2    -Z4  -Hop/2+RS   0.0    -Z5    Rfeed
GW 36     1    +RS     FeedSep/2    -Z6  +Hop/2+RS   0.0    -Z5    Rfeed
GW 37     1    +RS    -FeedSep/2    -Z4  +Hop/2+RS   0.0    -Z5    Rfeed
' LOWER-MIDDLE CROSS-OVER FEEDLINE:
GW 38     1    +RS     FeedSep/2     Z12     +RS        FeedSep/2     Z14    Rfeed
GW 39     1    +RS    -FeedSep/2     Z12     +RS       -FeedSep/2     Z14    Rfeed
GW 40     1    +RS    -FeedSep/2     Z16   Hop/2+RS  0.0     Z15    Rfeed
GW 41     1    +RS     FeedSep/2     Z14   Hop/2+RS  0.0     Z15    Rfeed
GW 42     1    +RS     FeedSep/2     Z16  -Hop/2+RS  0.0     Z15    Rfeed
GW 43     1    +RS    -FeedSep/2     Z14  -Hop/2+RS  0.0     Z15    Rfeed
GW 44     4    +RS     FeedSep/2     Z16     +RS        FeedSep/2     Z18    Rfeed
GW 45     4    +RS    -FeedSep/2     Z16     +RS       -FeedSep/2     Z18    Rfeed
GW 46     1    +RS     FeedSep/2    -Z12     +RS        FeedSep/2    -Z14    Rfeed
GW 47     1    +RS    -FeedSep/2    -Z12     +RS       -FeedSep/2    -Z14    Rfeed
GW 48     1    +RS    -FeedSep/2    -Z16  -Hop/2+RS  0.0    -Z15    Rfeed
GW 49     1    +RS     FeedSep/2    -Z14  -Hop/2+RS  0.0    -Z15    Rfeed
GW 50     1    +RS     FeedSep/2    -Z16  +Hop/2+RS  0.0    -Z15    Rfeed
GW 51     1    +RS    -FeedSep/2    -Z14  +Hop/2+RS  0.0    -Z15    Rfeed
GW 52     4    +RS     FeedSep/2    -Z16     +RS        FeedSep/2    -Z18    Rfeed
GW 53     4    +RS    -FeedSep/2    -Z16     +RS       -FeedSep/2    -Z18    Rfeed
' OUTER CROSS-OVER FEEDLINE:
GW 54     1    +RS     FeedSep/2     Z22     +RS        FeedSep/2     Z24    Rfeed
GW 55     1    +RS    -FeedSep/2     Z22     +RS       -FeedSep/2     Z24    Rfeed
GW 56     1    +RS    -FeedSep/2     Z26   Hop/2+RS  0.0     Z25    Rfeed
GW 57     1    +RS     FeedSep/2     Z24   Hop/2+RS  0.0     Z25    Rfeed
GW 58     1    +RS     FeedSep/2     Z26  -Hop/2+RS  0.0     Z25    Rfeed
GW 59     1    +RS    -FeedSep/2     Z24  -Hop/2+RS  0.0     Z25    Rfeed
GW 60     4    +RS     FeedSep/2     Z26     +RS        FeedSep/2     Z28    Rfeed
GW 61     4    +RS    -FeedSep/2     Z26     +RS       -FeedSep/2     Z28    Rfeed
GW 62     1    +RS     FeedSep/2    -Z22     +RS        FeedSep/2    -Z24    Rfeed
GW 63     1    +RS    -FeedSep/2    -Z22     +RS       -FeedSep/2    -Z24    Rfeed
GW 64     1    +RS    -FeedSep/2    -Z26  -Hop/2+RS  0.0    -Z25    Rfeed
GW 65     1    +RS     FeedSep/2    -Z24  -Hop/2+RS  0.0    -Z25    Rfeed
GW 66     1    +RS     FeedSep/2    -Z26  +Hop/2+RS  0.0    -Z25    Rfeed
GW 67     1    +RS    -FeedSep/2    -Z24  +Hop/2+RS  0.0    -Z25    Rfeed
GW 68     4    +RS     FeedSep/2    -Z26     +RS        FeedSep/2    -Z28    Rfeed
GW 69     4    +RS    -FeedSep/2    -Z26     +RS       -FeedSep/2    -Z28    Rfeed
' UP TO 43 PAIRS OF REFLECTOR RODS:
GW 71 9 0.0 -YRod 20*RR  0.0 -Rgap/2 20*RR  Rrod
GW 72 9 0.0 -YRod 19*RR  0.0 -Rgap/2 19*RR  Rrod
GW 73 9 0.0 -YRod 18*RR  0.0 -Rgap/2 18*RR  Rrod
GW 74 9 0.0 -YRod 17*RR  0.0 -Rgap/2 17*RR  Rrod
GW 75 9 0.0 -YRod 16*RR  0.0 -Rgap/2 16*RR  Rrod
GW 76 9 0.0 -YRod 15*RR  0.0 -Rgap/2 15*RR  Rrod
GW 77 9 0.0 -YRod 14*RR  0.0 -Rgap/2 14*RR  Rrod
GW 78 9 0.0 -YRod 13*RR  0.0 -Rgap/2 13*RR  Rrod
GW 79 9 0.0 -YRod 12*RR  0.0 -Rgap/2 12*RR  Rrod
GW 80 9 0.0 -YRod 11*RR  0.0 -Rgap/2 11*RR  Rrod
GW 81 9 0.0 -YRod 10*RR  0.0 -Rgap/2 10*RR  Rrod
GW 82 9 0.0 -YRod  9*RR  0.0 -Rgap/2  9*RR  Rrod
GW 83 9 0.0 -YRod  8*RR  0.0 -Rgap/2  8*RR  Rrod
GW 84 9 0.0 -YRod  7*RR  0.0 -Rgap/2  7*RR  Rrod
GW 85 9 0.0 -YRod  6*RR  0.0 -Rgap/2  6*RR  Rrod
GW 86 9 0.0 -YRod  5*RR  0.0 -Rgap/2  5*RR  Rrod
GW 87 9 0.0 -YRod  4*RR  0.0 -Rgap/2  4*RR  Rrod
GW 88 9 0.0 -YRod  3*RR  0.0 -Rgap/2  3*RR  Rrod
GW 89 9 0.0 -YRod  2*RR  0.0 -Rgap/2  2*RR  Rrod
GW 90 9 0.0 -YRod  1*RR  0.0 -Rgap/2  1*RR  Rrod
GW 101 9 0.0 YRod 20*RR  0.0 Rgap/2 20*RR  Rrod
GW 102 9 0.0 YRod 19*RR  0.0 Rgap/2 19*RR  Rrod
GW 103 9 0.0 YRod 18*RR  0.0 Rgap/2 18*RR  Rrod
GW 104 9 0.0 YRod 17*RR  0.0 Rgap/2 17*RR  Rrod
GW 105 9 0.0 YRod 16*RR  0.0 Rgap/2 16*RR  Rrod
GW 106 9 0.0 YRod 15*RR  0.0 Rgap/2 15*RR  Rrod
GW 107 9 0.0 YRod 14*RR  0.0 Rgap/2 14*RR  Rrod
GW 108 9 0.0 YRod 13*RR  0.0 Rgap/2 13*RR  Rrod
GW 109 9 0.0 YRod 12*RR  0.0 Rgap/2 12*RR  Rrod
GW 100 9 0.0 YRod 11*RR  0.0 Rgap/2 11*RR  Rrod
GW 101 9 0.0 YRod 10*RR  0.0 Rgap/2 10*RR  Rrod
GW 102 9 0.0 YRod  9*RR  0.0 Rgap/2  9*RR  Rrod
GW 103 9 0.0 YRod  8*RR  0.0 Rgap/2  8*RR  Rrod
GW 104 9 0.0 YRod  7*RR  0.0 Rgap/2  7*RR  Rrod
GW 105 9 0.0 YRod  6*RR  0.0 Rgap/2  6*RR  Rrod
GW 106 9 0.0 YRod  5*RR  0.0 Rgap/2  5*RR  Rrod
GW 107 9 0.0 YRod  4*RR  0.0 Rgap/2  4*RR  Rrod
GW 108 9 0.0 YRod  3*RR  0.0 Rgap/2  3*RR  Rrod
GW 109 9 0.0 YRod  2*RR  0.0 Rgap/2  2*RR  Rrod
GW 100 9 0.0 YRod  1*RR  0.0 Rgap/2  1*RR  Rrod
GW 111 9 0.0 -YRod  -1*RR 0.0 -Rgap/2   -1*RR Rrod
GW 112 9 0.0 -YRod  -2*RR 0.0 -Rgap/2   -2*RR Rrod
GW 113 9 0.0 -YRod  -3*RR 0.0 -Rgap/2   -3*RR Rrod
GW 114 9 0.0 -YRod  -4*RR 0.0 -Rgap/2   -4*RR Rrod
GW 115 9 0.0 -YRod  -5*RR 0.0 -Rgap/2   -5*RR Rrod
GW 116 9 0.0 -YRod  -6*RR 0.0 -Rgap/2   -6*RR Rrod
GW 117 9 0.0 -YRod  -7*RR 0.0 -Rgap/2   -7*RR Rrod
GW 118 9 0.0 -YRod  -8*RR 0.0 -Rgap/2   -8*RR Rrod
GW 119 9 0.0 -YRod  -9*RR 0.0 -Rgap/2   -9*RR Rrod
GW 120 9 0.0 -YRod -10*RR 0.0 -Rgap/2  -10*RR Rrod
GW 121 9 0.0 -YRod -11*RR 0.0 -Rgap/2  -11*RR Rrod
GW 122 9 0.0 -YRod -12*RR 0.0 -Rgap/2  -12*RR Rrod
GW 123 9 0.0 -YRod -13*RR 0.0 -Rgap/2  -13*RR Rrod
GW 124 9 0.0 -YRod -14*RR 0.0 -Rgap/2  -14*RR Rrod
GW 125 9 0.0 -YRod -15*RR 0.0 -Rgap/2  -15*RR Rrod
GW 126 9 0.0 -YRod -16*RR 0.0 -Rgap/2  -16*RR Rrod
GW 127 9 0.0 -YRod -17*RR 0.0 -Rgap/2  -17*RR Rrod
GW 128 9 0.0 -YRod -18*RR 0.0 -Rgap/2  -18*RR Rrod
GW 129 9 0.0 -YRod -19*RR 0.0 -Rgap/2  -19*RR Rrod
GW 130 9 0.0 -YRod -20*RR 0.0 -Rgap/2  -20*RR Rrod
GW 131 9 0.0 YRod  -1*RR 0.0 Rgap/2  -1*RR Rrod
GW 132 9 0.0 YRod  -2*RR 0.0 Rgap/2  -2*RR Rrod
GW 133 9 0.0 YRod  -3*RR 0.0 Rgap/2  -3*RR Rrod
GW 134 9 0.0 YRod  -4*RR 0.0 Rgap/2  -4*RR Rrod
GW 135 9 0.0 YRod  -5*RR 0.0 Rgap/2  -5*RR Rrod
GW 136 9 0.0 YRod  -6*RR 0.0 Rgap/2  -6*RR Rrod
GW 137 9 0.0 YRod  -7*RR 0.0 Rgap/2  -7*RR Rrod
GW 138 9 0.0 YRod  -8*RR 0.0 Rgap/2  -8*RR Rrod
GW 139 9 0.0 YRod  -9*RR 0.0 Rgap/2  -9*RR Rrod
GW 140 9 0.0 YRod -10*RR 0.0 Rgap/2 -10*RR Rrod
GW 141 9 0.0 YRod -11*RR 0.0 Rgap/2 -11*RR Rrod
GW 142 9 0.0 YRod -12*RR 0.0 Rgap/2 -12*RR Rrod
GW 143 9 0.0 YRod -13*RR 0.0 Rgap/2 -13*RR Rrod
GW 144 9 0.0 YRod -14*RR 0.0 Rgap/2 -14*RR Rrod
GW 145 9 0.0 YRod -15*RR 0.0 Rgap/2 -15*RR Rrod
GW 146 9 0.0 YRod -16*RR 0.0 Rgap/2 -16*RR Rrod
GW 147 9 0.0 YRod -17*RR 0.0 Rgap/2 -17*RR Rrod
GW 148 9 0.0 YRod -18*RR 0.0 Rgap/2 -18*RR Rrod
GW 149 9 0.0 YRod -19*RR 0.0 Rgap/2 -19*RR Rrod
GW 150 9 0.0 YRod -20*RR 0.0 Rgap/2 -20*RR Rrod
GW 151 9 0.0 -YRod    0.0   0.0 -Rgap/2  0.0   Rrod    ' CENTER RR
GW 152 9 0.0  Rgap/2  0.0   0.0  YRod    0.0   Rrod    ' CENTER RR
GS 0 0 0.0254            ' CONVERT ABOVE FROM INCHES TO METERS FOR NEC.
GE 0                ' No Ground Plane
GN -1                ' Free Space
EK 0                ' Enable Extended Kernel
LD 5 0 0 0 Cond 0        ' Conductivity
EX 0 1 1 0 1 0        ' SOURCE on GW1, seg 1
' FR Freq Sweep choices in order of increasing calculation time (fm holl_ands):
FR 0 29 0 0 470 12      ' Freq Sweep 470-806 every 12 MHz - OLD UHF BAND
' FR 0 39 0 0 470 6        ' Freq Sweep 470-698 every 6 MHz - PREFERRED FOR UHF
' FR 0 77 0 0 470 3        ' Freq Sweep 470-698 every 3 MHz
' FR 0 153 0 0 470 1.5    ' Freq Sweep 470-698 every 1.5 MHz
' FR 0 71 0 0 300 10    ' Freq Sweep 300-1000 every 10 MHz - WIDEBAND SWEEP
' FR Hi-VHF choices:
' FR 0 15 0 0 174 3        ' Freq Sweep 174-216 every 3 MHz
' FR 0 29 0 0 174 1.5    ' Freq Sweep 174-216 every 1.5 MHz - PREFERRED
' FR 0 43 0 0 174 1        ' Freq Sweep 174-216 every 1 MHz - Hi-Rez
' FR 0 26 0 0 150 6        ' Freq Sweep 150-300 every 6 MHz - WIDEBAND SWEEP
' FR Lo-VHF choices:
' FR 0 19 0 0 54 3        ' Frequency Sweep every 3 MHz for Ch2-6 + FM
' FR 0 35 0 0 54 1        ' Frequency Sweep every 1 MHz for Ch2-6
' FR 0 36 0 0 75 1        ' Frequency Sweep every 1 MHz for Ch5 + Ch6 + FM
' RP choices in order of increasing calculation time:
' RP 0 1 1 1510 90 0 1 1 0 0    ' 1D Gain toward 90-deg Azimuth
' RP 0 1 37 1510 90 0 1 5 0 0     ' 2D (Left only) Azimuthal Gain Slice
RP 0 1 73 1510 90 0 1 5 0 0      ' 2D Azimuthal Gain Slice - PREFERRED
' RP 0 73 1 1510 90 0 5 1 0 0     ' 2D Elevation Gain Slice
' RP 0 73 73 1510 90 0 5 5 0 0     ' 3D Lower Hemisphere reveals antenna
' RP 0 285 73 1510 90 0 5 5 0 0    ' 3D Full Coverage obscures antenna
EN
Lawrence, Very good antenna info, thanks for the NEC file!!
The design modified to work of 470mhz to 614mhz made of 1" tubing.
The Lengths in the file of MmanaGal are in meter
HTML:
Freq(MHz) R(Ohm)  jX(Ohm)  SWR(300.0Ohm) Ga(dBi)  F/B(dB)
470.0     396.3   152.41   1.68          9.6      18.57
518.0     442.99  44.01    1.5           9.77     16.16
566.0     403.23  -13.17   1.35          10.06    13.94
614.0     370.11  6.49     1.23          10.31    10.76
MMANA-GAL basic is freeware an antenna-analyzing tool based on the moment method (MmanaGal-Basic Wires max. 512)
http://hamsoft.ca/pages/mmana-gal.php
Copy and paste in an editor of text and save as...( biQuad_feed.maa )
.maa file below.
Code:
BiQuad_Feed_Antenna_UHF
470.0
***Wires***
25
0.0,	-0.0143,	0.0,	0.0,	0.0143,	0.0,	0.0016,	-1
0.0,	0.0143,	0.0,	0.0,	0.04939,	0.0,	0.00254,	-1
0.0,	0.04939,	0.0,	0.0,	0.1403,	0.0898,	0.0127,	-1
0.0,	0.1403,	0.0898,	0.0,	0.0,	0.2301,	0.0127,	-1
0.0,	0.0,	0.2301,	0.0,	-0.1403,	0.0898,	0.0127,	-1
0.0,	-0.1403,	0.0898,	0.0,	-0.04939,	0.0,	0.0127,	-1
0.0,	-0.04939,	0.0,	0.0,	-0.0143,	0.0,	0.00254,	-1
0.0,	0.04939,	0.0,	0.0,	0.1403,	-0.0898,	0.0127,	-1
0.0,	0.1403,	-0.0898,	0.0,	0.0,	-0.2301,	0.0127,	-1
0.0,	0.0,	-0.2301,	0.0,	-0.1403,	-0.0898,	0.0127,	-1
0.0,	-0.1403,	-0.0898,	0.0,	-0.04939,	0.0,	0.0127,	-1
-0.1207,	0.0,	-0.0953,	-0.1207,	0.2762,	-0.0953,	0.0127,	-1
-0.1207,	0.0,	-0.0953,	-0.1207,	-0.2762,	-0.0953,	0.0127,	-1
-0.1207,	0.0,	0.0953,	-0.1207,	0.2762,	0.0953,	0.0127,	-1
-0.1207,	0.0,	0.0953,	-0.1207,	-0.2762,	0.0953,	0.0127,	-1
-0.1207,	-0.2762,	0.0953,	-0.1207,	-0.2762,	-0.0953,	0.0127,	-1
-0.1207,	0.2762,	0.0953,	-0.1207,	0.2762,	-0.0953,	0.0127,	-1
-0.1207,	0.0,	-0.0953,	-0.1207,	0.0,	-0.2334,	0.0127,	-1
-0.1207,	0.0,	-0.2334,	-0.1207,	-0.1587,	-0.2334,	0.0127,	-1
-0.1207,	0.0,	-0.2334,	-0.1207,	0.1587,	-0.2334,	0.0127,	-1
-0.1207,	0.0,	0.0953,	-0.1207,	0.0,	0.2334,	0.0127,	-1
-0.1207,	0.0,	0.2334,	-0.1207,	-0.1587,	0.2334,	0.0127,	-1
-0.1207,	0.0,	0.2334,	-0.1207,	0.1587,	0.2334,	0.0127,	-1
0.0,	0.0,	0.2301,	-0.1207,	0.0,	0.2334,	0.003175,	-1
0.0,	0.0,	-0.2301,	-0.1207,	0.0,	-0.2334,	0.003175,	-1
***Source***
1,	0
w1c,	0.0,	1.0
***Load***
0,	0
***Segmentation***
800,	80,	2.0,	2
***G/H/M/R/AzEl/X***
0,	15.0,	4,	300.0,	120,	60,	0.0
Draw dimension in inch.
Schoolbus
Fat tubing elements in antenna 4-bay to cover 470mhz to 614mhz
Simulate in Mmanagal antenna-analyzing tool
I haven't done the testing
HTML:
470	  261.25  66.62	   1.32	          12.86	   17.93
518	  243.91  106.88   1.56	          13.54	   16.93
566	  323.64  167.68   1.71	          14.28	   16.17
614	  525.53  125.64   1.9	          14.5	   17.4
.maa file below.
Code:
Fat_Dipole_4bay_antenna_uhf
470.0
***Wires***
55
0.0,	0.0159,	0.381,	0.0,	0.2413,	0.381,	0.0127,	-1
0.0,	-0.0159,	0.381,	0.0,	-0.2413,	0.381,	0.0127,	-1
0.0,	0.0159,	0.127,	0.0,	0.2413,	0.127,	0.0127,	-1
0.0,	-0.0159,	0.127,	0.0,	-0.2413,	0.127,	0.0127,	-1
0.0,	0.0159,	-0.127,	0.0,	0.2413,	-0.127,	0.0127,	-1
0.0,	-0.0159,	-0.127,	0.0,	-0.2413,	-0.127,	0.0127,	-1
0.0,	0.0159,	-0.381,	0.0,	0.2413,	-0.381,	0.0127,	-1
0.0,	-0.0159,	-0.381,	0.0,	-0.2413,	-0.381,	0.0127,	-1
0.0,	0.0159,	0.0,	0.0,	0.0159,	0.127,	0.00162,	-1
0.0,	0.0159,	0.127,	0.0,	0.0159,	0.3016,	0.00162,	-1
0.0,	0.0159,	0.3016,	0.0064,	0.0,	0.3175,	0.00162,	-1
0.0064,	0.0,	0.3175,	0.0,	-0.0159,	0.3334,	0.00162,	-1
0.0,	-0.0159,	0.3334,	0.0,	-0.0159,	0.381,	0.00162,	-1
0.0,	0.0159,	0.0,	0.0,	0.0159,	-0.127,	0.00162,	-1
0.0,	0.0159,	-0.127,	0.0,	0.0159,	-0.3016,	0.00162,	-1
0.0,	0.0159,	-0.3016,	0.0064,	0.0,	-0.3175,	0.00162,	-1
0.0064,	0.0,	-0.3175,	0.0,	-0.0159,	-0.3334,	0.00162,	-1
0.0,	-0.0159,	-0.3334,	0.0,	-0.0159,	-0.381,	0.00162,	-1
0.0,	-0.0159,	0.0,	0.0,	-0.0159,	0.127,	0.00162,	-1
0.0,	-0.0159,	0.127,	0.0,	-0.0159,	0.3016,	0.00162,	-1
0.0,	-0.0159,	0.3016,	-0.0064,	0.0,	0.3175,	0.00162,	-1
-0.0064,	0.0,	0.3175,	0.0,	0.0159,	0.3334,	0.00162,	-1
0.0,	0.0159,	0.3334,	0.0,	0.0159,	0.381,	0.00162,	-1
0.0,	-0.0159,	0.0,	0.0,	-0.0159,	-0.127,	0.00162,	-1
0.0,	-0.0159,	-0.127,	0.0,	-0.0159,	-0.3016,	0.00162,	-1
0.0,	-0.0159,	-0.3016,	-0.0064,	0.0,	-0.3175,	0.00162,	-1
-0.0064,	0.0,	-0.3175,	0.0,	0.0159,	-0.3334,	0.00162,	-1
0.0,	0.0159,	-0.3334,	0.0,	0.0159,	-0.381,	0.00162,	-1
0.0,	-0.0159,	0.0,	0.0,	0.0159,	0.0,	0.00162,	-1
-0.1524,	0.0,	0.508,	-0.1524,	0.3683,	0.508,	0.0127,	-1
-0.1524,	0.0,	0.508,	-0.1524,	-0.3683,	0.508,	0.0127,	-1
-0.1524,	0.0,	0.381,	-0.1524,	0.3683,	0.381,	0.0127,	-1
-0.1524,	0.0,	0.381,	-0.1524,	-0.3683,	0.381,	0.0127,	-1
-0.1524,	0.0,	0.254,	-0.1524,	0.3683,	0.254,	0.0127,	-1
-0.1524,	0.0,	0.254,	-0.1524,	-0.3683,	0.254,	0.0127,	-1
-0.1524,	0.0,	0.127,	-0.1524,	0.3683,	0.127,	0.0127,	-1
-0.1524,	0.0,	0.127,	-0.1524,	-0.3683,	0.127,	0.0127,	-1
-0.1524,	0.0,	0.0,	-0.1524,	0.3683,	0.0,	0.0127,	-1
-0.1524,	0.0,	0.0,	-0.1524,	-0.3683,	0.0,	0.0127,	-1
-0.1524,	0.0,	-0.127,	-0.1524,	0.3683,	-0.127,	0.0127,	-1
-0.1524,	0.0,	-0.127,	-0.1524,	-0.3683,	-0.127,	0.0127,	-1
-0.1524,	0.0,	-0.254,	-0.1524,	0.3683,	-0.254,	0.0127,	-1
-0.1524,	0.0,	-0.254,	-0.1524,	-0.3683,	-0.254,	0.0127,	-1
-0.1524,	0.0,	-0.381,	-0.1524,	0.3683,	-0.381,	0.0127,	-1
-0.1524,	0.0,	-0.381,	-0.1524,	-0.3683,	-0.381,	0.0127,	-1
-0.1524,	0.0,	-0.508,	-0.1524,	0.3683,	-0.508,	0.0127,	-1
-0.1524,	0.0,	-0.508,	-0.1524,	-0.3683,	-0.508,	0.0127,	-1
-0.129,	0.0,	0.3175,	-0.129,	0.0,	0.5271,	0.0127,	-1
-0.0286,	0.0,	0.3175,	-0.0286,	0.0,	0.4,	0.0127,	-1
-0.129,	0.0,	-0.5271,	-0.129,	0.0,	-0.3175,	0.0127,	-1
-0.129,	0.0,	-0.3175,	-0.129,	0.0,	0.3175,	0.0127,	-1
-0.0286,	0.0,	-0.4,	-0.0286,	0.0,	-0.3175,	0.0127,	-1
-0.0286,	0.0,	-0.3175,	-0.0286,	0.0,	0.3175,	0.0127,	-1
-0.0286,	0.0,	0.3175,	-0.129,	0.0,	0.3175,	0.0031,	-1
-0.0286,	0.0,	-0.3175,	-0.129,	0.0,	-0.3175,	0.0031,	-1
***Source***
1,	0
w29c,	0.0,	1.0
***Load***
0,	0
***Segmentation***
800,	80,	2.0,	2
Premium Member
HTML:
Nice design, jop. That's just what I had in mind in post #6, but scaled for the new UHF band.
Do I have your permission to show your antenna design with your credit line in a post?
Premium Member
Yeah, 608 to 614 is channel 37, which is for other services, not DTV. Making the elements a little longer would increase the gain at the low end.
Discussion Starter #20 (Edited)
Major Tom,
Thank-you! Looks like the rescaled 8 bay fat dipole has an extra .5 to 1 full DB improvement,
(across the new UHF Spectrum) over Hollands original 8 Bay Fat dipole.
I think I will build it!
2 questions:
1. How and where do I paste in the NEC program script in my computer files/4NEc2 App?, so I can pull up all the dimensions and spacing?
2. Does it matter if I use those rods or can I just use fencing as a reflector? Does it change the results.
Thanks!
Schoolbus
1 - 20 of 46 Posts
