I posted this in another forum but also put it here because I think this is very important technology that needs to be shared. I need to clarify first of all, that I do not work for Televes and I was not comped anything free. In fact, because this is a beta unit, I have to return it. I first learned about SmartKom recently on a Facebook page. Some of the other members were already testing this, so I asked to try it myself. It was mailed from another independent tester to me when he was done testing it.
First of all, this is new technology that is similar to the Avant X but better in many ways. First of all, the most amazing thing is it does its own scan with a push of a micro button. There is a button on the Mast mounted section and also on the PSU so you can auto scan it from the roof or tower, or you can auto scan it from your PSU wherever you have it plugged in. You simply hold the button down until the LED flashes and then within seconds it gathers all receivable RF channels from each array of up to three, sorts out the strongest from each array and chooses what it "feels" is the best on one, two, or three inputs.
Similar to the Avant X it balances the Spectrum and the MER and C/N. What this does this essentially is allow you to combine up to three markets without losing any signal quality due to phase mismatch as compared to a splitter in reverse or other combiners. Many of us know how much of a disaster that is, combining two antennas from different markets with a splitter/combiner.
If need be, you can move channels around if you have the same RF channel # in two different markets. Because the Chicago market and Milwaukee Market don't use any of the same RF channel numbers on any full power stations, I could get away without moving any stations in the "map".
In rare cases like mine, SmartKom actually misinterpreted a Chicago signal on my Milwaukee antenna, because the AGC in my 148383 actually lowered the gain on the strongest signals and my AGC at my Milwaukee antenna raised the gain! :
No problem. All I had to do was drop and drag the stations RF 19, 20 and 22 back over to input 1 using A Suite on my smartphone and send the adjustment over to the PSU via Bluetooth.
The adjustment took place instantly and balanced my Spectrum:
For now until the US version comes out the SmartKom uses "Easy F" coax cable attachments. This will change when the American Market version comes out which will have threaded F connectors.
Because it can be used indoors and better yet, outdoors it is in a waterproof case for mast mounting. It's really designed to be outside on the mast for combining antennas and eliminating all but one downlead.:
All of my testing was done indoors for this round:
PSU W LED and Scan Button in center:
What phase mismatch and multipath looks like with when one market is closer and stronger (Chicago) :
"A Suite" is the app that I use with SmartKom :
Test subjects. Chicago on top 168° South. Milwaukee 358° North.
Twin 148383s :
Since I play around lot with TV antennas I have six leads going into the house I'll just ask this question. Does anybody know a quality switching system that can handle 4 to 5 different antenna arrays at one time for real time testing purposes?
Radio Shack 15-1266A?
Twin 148383s :
