1 - 1 of 1 Posts
At Cedia, Connectivity solutions provider Gefen is showing its Wireless for HDMI extension solution for transmitting high definition video and audio wirelessly. This next generation, no-cable extender uses high definition wireless technology by Amimon that operates in the 5GHz unlicensed band to deliver uncompressed audio and video in the HDMI format up to 30 meters (90-feet) in distance.
The GefenTV Wireless for HDMI Extender comes in a two-box solution, with the sender unit connected to the HD source and the receiver unit connected to the remote HD display. This no-cable extender delivers hi-def resolutions to 1080i with HDCP compliance, resulting in a performance equal to wired solutions with no signal delay. Additionally, there is no line-of-sight required, making this solution desirable in hard to reach locations or where equipment is located in out-of-sight racks.
1 - 1 of 1 Posts
