401 - 413 of 413 Posts
Not really, I can easily compare the actual PQ's where as you can guess what they could be like. But carry on believing your theory, come back to me when you've watch Netflix Super HD PQ and compared it with cable, IPTV, blu-ray and up converted DVD's..........all of which I am able to do.
I think you might have breathed in too much insect killer in Winnipeg.
"I've never seen it but its sh*t"......that's hysterical
four said:
Blu-ray is not good high definition. Blu-ray is high definition.
"High definition" typically means (in the TV space) 1920x1080 or 1280x720. Plenty of other services and storage devices other than Blu-ray support those resolutions.
If you believe than nothing other than Blu-ray is high definition, then you're making up your own definitions for the term.
four said:
2-pass encoding? Never heard they know what that means, doubt it very much.
IIRC, they use real-time encoders, adjusting to the bandwidth available.
Just like they did here with a test H.265 stream
Netflix content is pre-encoded at each supported codec and bitrate. Practically all streaming video services work this way. If you think that Netflix uses real-time encoding, well, you're nuts. Seriously, do you not comprehend how expensive that would be for their server's processors? Even suggesting that they use real-time encoding tells me how much you know about the topic. Sure, Netflix can change bitrates, but each bitrate is encoded separately.
The idea that they'd do real-time encoding with 4K content is even more hilarious. It would literally be >100,000 times more expensive in compute cycles.
If you know so much, then why do you think Netflix does real time encoding per stream? Encoding h.264 is very expensive. Anyone slightly knowledgeable about the subject would know better.
Encoding H.264 is very cheap.
How can you believe anybody who does not know even that...
I had enough of your rhetoric for today...
Nope, encoding video is expensive; even a 4-core x86 server couldn't support more than what, 8 users if it was doing real-time encoding of HD video streams. At a (max) of 5mbps per stream it would only be able to send about 40mbps (tops!) of stream data if it was doing real-time encoding.
So, with that in mind let's take a look at Netflix Open Connect hardware...
It has a Xeon E3-1260L, which is a 4-core chip, and it has a 10Gbps Ethernet NIC. It's interesting that Netflix would equip a server with a single middle-of-the-road Xeon CPU and pair it with a high-end 10Gbps NIC when a 100mbps NIC would be able to keep up with the Xeon E3-1260L if the Xeon was doing real-time encoding of every stream.
At least, I think that's interesting. If you were right and Netflix was doing real-time encoding, you would think that they'd put a 2nd CPU in their Open Connect hardware. More likely, you would think they'd equip it with a ridiculous amount of encoding horsepower, but they didn't.
Now, if they pre-encoded the video (and they do), then streaming pre-encoded video has similar CPU cost as reading a file from disk and sending it out the NIC. In that case each of these Open Connect boxes would be able to get close to saturating a 10Gbps NIC. In other words, that box could probably handle ~1900-2000 concurrent streams.
And then there is the slight detail that Netflix doesn't even list encoding software on the Software Design page. You know why that is? Because the servers that Netflix client software interacts with don't do real time encoding.
Well, at least you've demonstrated that you know as much about video encoding as you do about TRIM.
Encoding and decoding H.264 is typically done with dedicated hardware, not a general purpose CPU (unless it's on a home PC.) It would likely still be impractical for Netflix to do it in real time for every customer though.
I believe all material is pre-rendered for various platforms and speeds, then the most suitable rendered files are streamed to the end customer.
Much better than trying to render everything in real time.
That used to be true. The reason why the industry started using dedicated h.264 hardware was that general purpose CPUs combined with the software encoders available at the time weren't fast enough to do real time encoding. Since then both the software has improved and the general purpose hardware got faster.
The best encoding (i.e. highest quality) was always available via software encoding - primarily because engineers can iterate/improve with software much faster than hardware, so if you're doing offline encoding of videos (e.g. a batch job), then you would likely always have been using a software encoder.
Today, there isn't much motivation to ever use dedicate hardware encoders (e.g. custom ASIC) because general purpose CPUs with software encoding are fast enough to encode a single real-time h.264 HD stream at 60fps, especially when utilizing hardware extensions like Intel's QuickSync, but even without QuickSync you can easily achieve 24fps in real time. Even 60fps can be done if your CPU is fast enough.
Many of today's encoders can now use the GPU of a high-end graphics card to do the work instead of the computer's CPU. My Sony Vegas NLE software supports this. Unfortunately, the graphics card is very low-end and is just too slow to be supported.
I agree that better encoding can be obtained using software. My system, not a screamer by any means, has a 6 core AMD CPU and a middle of the line AMD video card. H.264 encoding done by the video card is about 4 times faster than software and CPU but still not real time and the quality is poor. A newer Intel CPU would be better but still I don't see Netflix doing much real time encoding.
Francois, thanks for that piece of info regarding Netflix. I had a hunch they were simply switching sources for the streams but didn't really know. It would be interesting to know how they manage to keep the video and audio in sync with adaptive streaming speeds. I can see the video quality change but have yet to see any dropped frames or other artifacts.
You don't need high end video cards to do hardware transcoding - the last three gens of Intel CPUs have done this, known as Quick Sync, although the Haswell CPUs have a much better implementation with better quality.
