Got it working: Netflix Canada on Roku
So this has been a large pain in the *** that I've been trying to solve for a while...!
Up to this point the limitation in getting the Roku working with Netflix is that it would not retrieve an activation code. I manged to get past this with the following steps - this assumes you have a valid Cdn Netflix account:
1. Make your network appear to be US based by using http://portal.unblock-us.com...the basic steps are: log into your router and change the primary and secondary DNS address to (remember to write down your current numbers):
Primary DNS 208.122.23.22
Secondary DNS 208.122.23.23
2. reboot router
3. open up any webpage - UnblockUS will ask for your e-mail address to set up a trial account. Enter your e-mail address.
4. Go to the Roku store and add Netflix
5. Enter the Netflix app and indicate that you are a current customer.
6. A code will appear - you need to enter this code here: https://account.netflix.com/Activate
7. you should get a message that "Activation is Complete"
8. You may need to exit the Netflix app at this point. When you re-enter you will see the US catalog. This is good
. Exit app.
9. Now to return to Canada - go back to your router and restore the original DNS numbers.
10. Netflix should now work with the cdn library.
Good luck!
T2
2. reboot router
Good luck!
T2
