1 - 8 of 8 Posts
Hello,
I just purchased a Panasonic Plasma, TC-P50U2, a couple of weeks ago.
I've noticed that movies have a strong greenish tint. In dark scenes, blacks and greys have a strong greenish hue. Bright scenes are better but a green bias can still be seen. TV shows are fine, I only have this problem with movies. This happens regardless of the source i.e. whether I'm watching a movie from a blu-ray player or a movie shown in cable.
I've tried adjusting the brightness level but it did not help. Increasing the color level helps a bit, but this makes all the colors look unnatural. Adjusting tint has not helped.
I have Disney's WOW calibration disc, I have tried the Basic and Advanced optimization and so far have had no luck here as well.
Thanks in advance for your help!
Sounds like a greyscale issue.
Are you using the same picture mode/input type for TV and movies?
Depending on what you have brightness/contrast set to those might cause a greyscale shift.
As doglips has pointed out a calibration is probably the best option but only after you check the obvious things first.
Greetings
Change the color temp setting over to normal or cool to see if the green tint goes away.
Those settings have separate numbers in memory ... versus the warm mode.
regards
Since you are in the GTA might I suggest you contact one of the moderators on this site known as 57. He calibrated and set up our bedroom 32" Sharp LED/LCD a few months ago and did a wonderful job. I was in TV repair for many years (in the dark ages) and these new digital flat screen TVs are a challenge for sure. Just a thought. Here is his calibration email address
http://www.digitalhome.ca/forum/showthread.php?t=40306
Discussion Starter · #7 · (Edited)
Thanks to all who replied to my post, here's some additional information:
-Samsung C6500 Blu-ray player is directly connected to the TV via HDMI
-Rogers STB is directly connected to the TV via HDMI
Here are my current settings, all values are factory/default settings except for Custom:
Cinema Standard Game Custom Vivid
Contrast 100 100 100 100 100
Brightness 58 50 50 52 50
Color 51 50 50 50 60
Tint 0 0 0 2 0
Sharpness 50 75 75 50 78
Color temp Warm Normal Normal Normal Cool
xvColor Off Off Off Off Off
CATS Off On Off Off Off
Video NR Off Off Off Off Off
Aspect Adjustments:
Screen format full Full Full Full Full
HD Size Size 1 Size 1 Size 1 Size 1 Size 1
Advanced Picture:
MPEG NR Off Off Off Off Off
Black level Light Light Light Light Light
-I have tried all combinations of picture mode (standard, cinema, vivid) and color temp (warm, normal, cool) - and I still see the same green tint instead of grey or black.
-I would like to try DIY calibration first, this is why I purchased a calibration disc.
The picture is perfect otherwise, it is just the dark scenes in movies where it's supposed to be showing greys and blacks but instead it shows up in greens. I know it should be showing greys because I watched the same movies on my DVD/CRT unit and these scenes are in grey and not green. I do not think there is a problem with the TV displaying blacks and greys because when displaying TV shows it shows these colours. So, I'm assuming the problem is somewhere in the settings.
-I'll try jvincent's advise to play around with brightness and contrast and see what happens. I would appreciate any other additional suggestions for me to try.
Thanks!
I have a similar set, P50S
I had similar issues with the greenish tint, especially in flesh tones. Not too bad, but it bothered me at times. I found that Normal temperature in Cinema mode and color set down to 30 helped considerably. FWIW I also lowered the contrast to 75, brightness to 60, sharpness and tint to 0. I played with the tint and while it sometimes helped, it was at the expense of accuracy in other colors to it sits at 0.
Sounds you are having more of an issue than me though. I haven't noticed the green effect in blacks and grays
1 - 8 of 8 Posts
