Status
Not open for further replies.
1 - 10 of 10 Posts
Hey guys,
I'd need your advice as to how to ground my antenna. I mean, I know I need to connect a copper or aluminium (no. 8 or 10) to a ground rod driven at least 3 feet into the ground. Thing is, my antenna is not on the side of the house were there's a flat wall that goes to the basement. It is the carport.
I've attached a picture of the front of the house. The red circle is were the booster is connected, therefore the ground my be connected just before that. I cannot do that on the back of the house as I have a wooden deck that prevent me to put a ground rod there. So must be on the side, or the front (which I'd need to cover somehow). I've read that I must avoid any 90 degree turns or heavy turn with the cable...based on my setup, will be hard to avoid.
So, question is. Is someone having a good suggestion about how to ground the antenna? I cannot move the antenna as on the side of the carport I'd be too low, and on the other side of the house I have a pine which goes twice the height of the house, so cannot put the antenna there either.
Any recommendation?
Thanks in advance for your help
Best Regards
Martin
Gounding needed for Attic install?
Hi, I have been trying to search the answer to my question and wasn't able to find it. Is it require?
I plan to run the cable from the attic down to my basement where I would plug it into the Roger split. Is that a good idea? This way, I wouldn't have to re-run all of my wires again to each room.
Antenna Grounding / Lighting Supression
I did a search but didn't see anything specific.
From what I have read you should ground the coax using a grounding block, and ground the antenna mast using a grounding rod.
If I do both, do I need any lightling supressors?
(BTW just picked up a DB8 and will be mounting it tomorrow.)
Do I Need To Ground An Indoor Antenna?
Hey Gang,
A friend purchased a 4221Hd for an interior setup in front of a patio door.I will modify (Hack) the 4221HD, but his question to you is:
Do you need to ground the antenna if it's inside the house?
I told him no, but he wants a second opinion.
Thanks,
I'm using one here in the apartment in a second bedroom nestled in the corner pointed at Toronto mounted to a freestanding patio table umbrella stand. Works like gangbusters.
Cameron
When you should ground an indoor antenna
Canadians have all experienced that dreadful static electricity zap in the middle of the winter as we walk across a rug in thick socks and accidentally touch the cover screw on a light switch... YOWWW!!!! :eek:
If there is any risk of this happening to an indoor antenna on which the elements are of exposed metal then ground it and be glad that you did. The blast from a shock like that could easily damage a tuner.
Otherwise I agree that there is no real reason to ground an indoor antenna.
For all the information you'll ever need about grounding please use our official Digital Home grounding thread: Grounding Info & Standards: OTA/Dish/CATV/Telecom
Worried about lightning strikes...
Hi,
I just put a CM4221HD on the balcony of my 34th floor apartment (second highest floor of my apartment). I don't have it "grounded" to anything and it is directly connected to my HD converter box. Should I be worried about lightning strikes? If so, is there any way for me to protect my equipment in case the lightning zaps my antenna? Not sure what the chances of lightning hitting my antenna are. There is a concrete roof above my balcony and the CN tower is about 15km away (I live near Bloor/Islington in Toronto).
1 - 10 of 10 Posts
Status
