1 - 20 of 20 Posts
has anyone else noticed this?
quite some weeks ago, the channels ('mux1' - 'mux4', iirc) for msnbc & cnbc vanished, now it's all the nbc channels, along with cozy tv that are apparently no longer broadcasted on 103w.
no amount of blind scans can bring them back.
fine on sunday two weeks ago, no-show on monday.
...just to confirm my dish is still properly aligned, the channels for nhk et al are still there and coming in fine.
The NBC east/west/central/mountain feeds as well as cozi were all coming in last night (Tues July 17) just fine for me here in London ON. The NBC channels are all on the Horizonal polarity, while NHK and the others are vertical. Perhaps your receiver isn't pushing out enough power to trigger the toggling of the LNB from Vertical to Horizontal polarity. It might be a bad connection in the cable somewhere too.
Discussion Starter #3
i was thinking maybe the signal is still there but something changed in the *format* of said signal, but my receiver is not seeing anything. no signal at all, not a sausage. i cannot fathom my amiko mini hd re would suddenly loose the ability to process the signal, as it has served me very well until very recently.
the two other birds i'm watching (125w for pbs, 87w for pbs louisiana and other channels) don't have any problem themselves.
i just did a test, flipping between various transponders on all 3 satellites, some horizontal, others vertical, no problem.
i will try to dig out my microhd (this is what the amiko replaced) to see if this makes a difference, asap.
are you still receiving the "nbc mux ch1-4 ft61-64" signals on tp12111?
those were the first ones to go.
cheers.
All coming in fine here. The 4 at 12135H are weak though, but picture is ok. No format or modulation changes as far as I can see. Maybe something moved your dish a bit?
What are you using for an antenna?
take a look at sat sig.
https://satsignature.com/plot/america/ses-3
it is one of the weaker TPs on that pol of that satellite. The only reason it does come in at all is that it only uses FEC 3/4, which requires a min of 7.9 dB SNR to lock. While most of the bigger TPs use 5/6 FEC and require at least 9.4 dB to lock. On my primestar antenna with a skewable mount, the weak mux plays fine at 7.9 dB (clear sky), but does not on the 7.5' BUD mesh C/Ku antenna. If it was using 5/6 FEC as well, no way it would be coming in here at all. So, there is No margin for error whatsoever. Does your antenna have a skewable mount, or are you having to set the skew via the LNB? An elliptical dish with a skewable mount can be better than a round dish without a skewable mount, especially on the lower sats. Ie higher the req skew setting, the better it should perform, all else being equal (equiv dish size).
STBs are NOT signal meters, most of them won't display anything for "Quality" when they are well below the lock threshold.
I helped the OP install and aim his dish. It is a 4' FG Channel Master, with the skew set on the LNB. It was peaked using the C/N ratio display in EBSPro on a laptop out by the dish, and we took a lot of pains to maximize the signal.
We had some very strong winds through here a couple of weeks ago, so it could be the dish got moved slightly.
Discussion Starter #7
the fact that the footing for this dish is not as robust as the one for my 125w dish, and thus could have shifted just a touch is starting to sink in. (background: because of buried bell cables and gas lines in my backyard, i have everything "floating" and not buried). i will check to see if this dish's setup needs to be leveled again and possibly made sturdier.
if i'm off every so slightly but am still getting nhk et al, it shows how strong those signals are.
Right now on my own 4' CM dish on 103W, I'm getting Cozi (11760 H) and NBC MUX CH1 FT61 et al (12134 H) with good strength (plus a bunch of other transponders on 103W).
Are you receiving any horizontal TPs on 103W? (if you're not, then I would guess your LNB has failed on that polarity). Is it the Inverto or Avenger you're using on that dish?
Yeah, all bets are off without a stable & plumb mount to start with.
My primestar w/skewable mount pole is in concrete, below the frost line.
Forget trying to compare the H to V polarization as that information is useless.
Most of the Vert TPs are DVB-S on that SAT. With DVB-S one can be off by a mile and still receive.
H Pol is all DVB-S2 on that sat, and for DVB-S2 signals everything needs to be spot on, No slop allowed.
Discussion Starter #10
DXer:
it's the inverto. the avenger is still mounted on the 90cm dish, currently in the backyard shed.
i'm not home right now, can't answer anything else atm.
Almost need a good Andrews/Ch Master 1.8m dish to get any decent headroom on 12135 H. My 1.2m ch master dish, you can push on the mast a bit in any direction and signal drops below threshold. Also I am not using the proper feed-horn, just using a dual output SL2PLL LNBF. Wouldn't mind finding a proper Ku feed-horn with H and V output for this dish. Have some LNBs kicking around I could use.
Do you have the original feedhorn for the dish? The OP and I both use an Inverto LNB with voltage polarity switching and a C120 flange that bolts right onto the feedhorn. Also, I've removed the scalars from two Avenger PLL LNBs and grafted them onto the original feedhorn. They give an improved S/N over using them as a standard LNBF.
Discussion Starter #13
a quick check yesterday evening with a torpedo level seem to show the mast holding the 1.2m dish being pretty much straight. afterwards, going through all the channels that still come in (nhk, cgtn, etc.), confirmed they are all vertical polarized.
no horizontal ones seem to be coming in.
it is still a good idea to make things sturdier asap, but the dish being off-kilter might not be the explanation to what's been happening to me. i will have to swap the inverto lnb for the avenger as soon as time allows to verify the possibility my current lnb going bad. as naive as it sounds, i never thought it could be possible.
cheers.
Discussion Starter #14
swapping the inverto lnb for a stock avenger dual lnb yielded the same result: nhk et al still there, nbc + cozi still absent.
ok, so the inverto did not become defective, it's the dish that is "just" off-kilter.
still impressed that nhk can come in fairly well despite a slightly misaligned dish. they must transmit at power level 11.
cheers.
The NHK transponder is QPSK, the NBC TP is 8psk. You require a much better signal to lock the higher order modulation. NBC is strong though even on a 90cm dish so must be out of alignment as you indicate. You should be able to get it back, just a bit of tweeking required. :)
103W is well worth the effort to receive. With my newly-installed 1.2-metre Ku dish, this satellite is strong and stable. The challenge as always was getting the motor to track correctly on the arc. This satellite plus 87W together make FTA worthwhile for those who live in an OTA-challenged city like Halifax with only 3 OTA channels.
103W is one of the last few remaning KU band sat that is worth watching.
Its a lot easier to receive since the skew was adjusted to the normal standard.
Jorgek: I guess it's just up to you and me. It seems everybody has abandoned this forum. Nobody playing with fta anymore?
Now that I have the motor lined up, NBC, COZI, NHK Japan are all beautifully strong.
My system is still the same, haven't made any changes in a while...
Most recent change was probably last fall, ran several hundred feet of new SC Coax thru my yard and in to my house.
Needed to be done as the old stuff was like 20 years old...
Finally, just about used the rest of that reel last week to run new downlead coax for my OTA antenna system to my basement.
C/Ku BUD from 127W to 55W...
a Fixed Primestar 84e antenna @ 103 W
Some PC based Sat tuners...
Prof 7500, TBS 5520SE (this can do DVB-S2x), DVBSKY S960, Geniatek hdstar,
An old Skystar sumthin or other with an early STB0899 Demod...
various STBs... 3 in use..
Nice system. It's worth having a dedicated fixed dish for 103W. Global Fashion channel disappeared yesterday. Since I got my motor hitting 103W just right, the quality of all channels on this satellite is good and stable all day long.
1 - 20 of 20 Posts
