I need a PVR solution!
I've found most of the answers I need to build a HTPC so far, except for a crucial one: which TV Tuner to use?
Here are my requirements:
1 - mainly needs to be able to record NTSC (Standard definition cable)
2 - costs need to stay low, ideally south of $600; MythTV is an appealing solution for this as the price is obviously hard to beat, but Tuner support appears very limited...
3 - digital is mostly an aftertought and not strictly required as Videotron doesn't carry any clear QAM - unless the card has dual entry: one for digital OTA and one for SD cable.
4 - Ideally, I'd rather have a PCIe card, unless someone confirms flawless recording/playback of NTSC (SD cable) through USB/PCI, with an AMD 4850e or similar cpu...
So far, I've read the Hauppage HVR-1250 is *not* supported for NTSC recording, the HVR-2250 is just not supported under Linux, and the HVR-1600 & 1800 have poor NTSC image quality. As for the ATI's 650, they don't seem to have Linux or MythTV support... (or NTSC, can't remember atm). I haven't head great things about the USB sticks either...
I'd rather stick with MythTV instead of wasting $150 for Vista Premium, but can't seem to find a TV Tuner that fits.
Does anyone have a TV Tuner to recommend? (working with MythTV + analog cable TV?)
Or is there another (cheap) PVR solution I haven't seen?
Thanks!
Thanks!
