Definitive Technology has announced a new model addition to the Mythos line of on-wall high loudspeakers. The new Mythos Nine is 28" L x 5-7/16" W x 43/16", is proportioned to match 50-inch flat panel video displays when used as a L/R speaker and appropriate for 42-inch and larger sets when used as a center channel speaker.
Each Mythos Nine contains two high-definition Balanced Dual Surround System (BDSS) 4-1/2" drivers that are pressure coupled to two 4-1/2" x 8" racetrack-shaped planar medite low-bass radiators. The two active 4-1/2 inch drivers surround a new generation Pure Aluminum dome tweeter, the same used in Definitive’s Mythos ST SuperTowers.
Mythos series enclosures are hand-polished aircraft-grade extruded Aluminum featuring proprietary damping technologies that ensure total rigidity. All components are mounted on a resonance-free PolyStone baffle.
The Mythos Nine is an L/C/R loudspeaker that can be used as either a front/surround left/right or center channel speaker. The user attaches the logo badge either at the bottom or side of the grille depending on whether the unit is used as a L/R or center channel speaker.
Both polished Aluminum and gloss Black finishes are available to match the most popular TV colors. The Mythos Nine will be available in November 2008 at a Suggested Retail Price of $799.95 each.
SPECIFICATIONS
Dimensions: 5-7/16" W x 28" L x 4-3/16" D (137mm x 711mm x 105mm)
Driver Complement:
– Two 4-1/2" BDSS cast basket bass/mid drivers
– Two 4-1/2" x 8" pressure-driven low-bass radiators
– One 1" Pure Aluminum dome tweeter
Frequency Response: 38 Hz – 30 kHz
Nominal Impedance: Compatible with 8 ohm outputs
Recommended Amplification: 10 – 250 Watts/channel
Sensitivity: 91 dB
Mounting Options: Steel wall-mount bracket and shelf
SPECIFICATIONS
Driver Complement:
Sensitivity: 91 dB
