1 - 20 of 32 Posts
1. Blu-ray(1080p)
2. THe best OTA Local Stations (1080i)
3. Telus Cable (720p)
4. Bell Satellite (720p preferred, some 1080i)
5. Shaw Direct (720p)
6. Shaw Cable (720p)
7. Netflix.ca (720p)
I use Blu-rays, Shaw and Telus Cable only so I am not familiar with the other sources. My rankings are just a guess, to make an example. For those that have experience with them please rank where you think they belong.
I wonder base on what/when did you rank Shaw against others. As I've said many times in the past, Shaw Vancouver has up'ed their significantly lower CBC HD bitrate, marginally lower Global HD bitrate and other local and US HD bitrates about a year ago to the point PQ is almost if not already identical to OTA. I've just done some more detailed analysis with solid numbers to confirm that. Please see my post linked below from the Shaw section for details.
http://www.digitalhome.ca/forum/showpost.php?p=1200200&postcount=1128
I have Bell Satellite and Shaw Cable, and I would put Shaw Cable well above Bell in picture quality. Bell has a noticeably softer picture than Shaw Cable on most HD channels. I can see this difference with my front projector on a 10 foot screen.
Bell Satellite has all their HD channels set at 720p and most HD channels broadcast at 1080i. Bell Sat. has the worst HD PQ of all providers, Shaw Cable/Direct , Rogers, Eastlink pass through each channels native resolution so we get what ever the channel is broadcasting at which most broadcast at 1080i with a few channels at 720p . Other than the occasional macroblocking the PQ looks great on Eastlink.
Discussion Starter · #10 ·
I rank Shaw by my Mar 2010 service.
Telus service was not available in my neighbourhood until Autumn 2010, so my ranking is from that time.
I may be wrong or misinformed but Shaw Direct broadcasts most HD channels in 1080i.
A couple newer channels are 720p. So I guess a more accurate depiction for post 1 would likely be (mostly 1080i, some 720p) as I understand it.
Happy New Year
Perhaps Shaw Cable's service is different in Victoria or your impression of Shaw's bad bitrate before January 2010 was still deeper. By March 2010, Shaw Cable in Vancouver has already got it's HD channel bitrates raised. In any case, your ranking of Shaw Cable is definitely outdated for Vancouver area.
Chris, if you really did look at the picture quality in equal footing there is no way you could possibly rank Bell TV's HD picture quality over Shaw Direct's HD picture quality, just saying...:confused:
I have no personal experience with Shaw Direct or other providers except Shaw Cable, which I find is as close to OTA as any provider could get and thus my comments. Perhaps my detailed analysis is overkill to most, but I keep reading people saying Shaw Cable has bad PQ so I just want to put those thoughts to rest. ;)
Discussion Starter · #20 ·
1. C-Band HD Network Feed- Where can I get that in BC? I like to have something better than Blu-ray.
2. Blu-Ray
3. OTA
4. Shaw Cable
5. Torrent via Media Center-Cannot comment on this because I have no experience with this plus is it not against forum rules to post about piracy.
6. Shaw Direct
7. Bell
8. Telus- suprised this is rated last as the two included movie channels on Shaw are very poor and the rest are around par with Shaw Cable.
I am going to have the service at same time later this year to do a direct comparison.
Also suprised because of all the negative comments on Bell in this thread. Surely my Telus Optik TV performance do not fit under these descriptions.
1 - 20 of 32 Posts
