Status
Not open for further replies.
1 - 2 of 2 Posts
I have 4 expressvu receivers (looking at a 5th) including a dual tuner pvr but have only 4 outputs with the standard multiswitch. My only option to increase the number of receivers is to install another dish. This seems silly with other satillite networks that can utilize larger multiswitches. Anyone know of compatible multiswitches with 6-8 outputs for expressvu?
There are no 5 or above output multiswitch's for Bell Tv that carry signals from BOTH birds, hoever there are 6 and 8 output for 91 ONLY.
The way to achieve over 5 outputs from a single Dish with Legacy Equipment, which you have now is this; Read posts 1, 3 & 5.
http://www.digitalhome.ca/forum/showthread.php?t=79134
With the addition of DPP Twin LNBF's to the Bell TV Approved Parts List, you can now run up to 12 Dual Tuner Receivers from a Single 20" Dish with only 2 lines entering the house by using the DPP Twin LNBF, followed by 3 x DPP44's in Cascade.
See this thread;
http://www.digitalhome.ca/forum/showthread.php?t=79131
1 - 2 of 2 Posts
Status
