1 - 3 of 3 Posts
My picture quality stinks - I am getting crazy amounts of macroblocking (choppiness) as well as little white dots (1 to 4 at a time) - the dots disappear when I change channels but then come back in different spots on the screen after a certain amount of time. The choppiness is always a problem with fast movement. My signal strength is excellent and my other standard def box on a 2nd TV looks great. Any ideas on what I should do? Do you think resetting the Terminal and wiping it clean will help? Change TV settings? Any advice from people who have the same issues would be really appreciated.
Have you contacted Videotron? What did they say?
1 - 3 of 3 Posts
