21 - 32 of 32 Posts
Discussion Starter #21
This is the lightning speed account i am paying for! If there is an MTS tech present can you please address this. DOWNLOAD 1.59 Mbps UPLOAD .43 Mbps From speedtest.net
relying on MTS to read this forum and fix your problem I would think would be an exercise in frustration. If you are having an issue you should call MTS and let them know. I know for a fact that they keep notes on every call, so you should be able to refer to your last calls and see if they can put in a new trouble ticket.
I recall hearing that on lines that have trouble maintaining a fast connection somehow, perhaps automatically, a slower profile is forced onto your connection. Once you have a slower profile you need to have someone manually force a higher profile through.
Just an observation :
I use uTorrent a lot. I keep torrent uploads running constantly and download less frequently.
I noticed something last week. I ran a SpeedTest to test my new connection ( we moved recently ) and found the speed to be horrible. It was 0.98 Mb. I ran a few more and the speed always stayed under 3.0 Mb. I had run a SpeedTest the first day we moved in and it was around 9.0 so I was a little miffed to see the level so low.
My torrent uploads were running about 236 Kb. Out of curiousity, I stopped the uploads. Speedtest went up to 7.0 Mb. I restarted the uploads, speed dropped to 2.5, stopped them again, speed increased, restarted, speed dropped.
I've tested this a few times during the past month and always had the same results. No uploadind - up to 9.0, uploading - slooow.
Am I being penalized for sharing ? Are we being monitored so closely that our connection speeds are constantly being altered ???
Might be something with your torrent software, I don't have that problem myself, and I believe (correct me if I am wrong) that MTS has already come out and said that they do not do any throttling or monitoring of traffic. Wasn't there a thread about that on here at one time?
Don J,
So you are doing separate tests with, and without torrents going? If so, of course you will see differences. Torrent software, depending on settings, can saturate (max out) your connection.
The original issue hasn't been fixed since the tech left the tag saying its an inside problem?
If you are on ADSL (the one where you plug a modem into any jack, and filter all your other jacks) then they may need to update the setup. They have a procedure in place where they dedicate one jack for the modem and install a central filter, and go over it all with a fine tooth comb.
They don't throttle as far as I know. Being DSL, your upload speed is lower than download. Nature of the technology. I don't think cable internet is much different. Business internet offers symmetrical speeds but is big $.
Please don't hesitate to call MTS. It probably can't be fixed over a forum.
(Authorized contractor for MTS, any views expressed are my own)
Don J, the solution is to limit the upload speed in uTorrent to less than the maximum upload speed (I would suggest 80%). Some Torrent clients will auto-configure the upload speed as part of the setup.
The reason to limit the upload speed is TCP/IP sends ACK packets when you are downloading. If the ACK packet can't get through fast enough because your upload stream is monopolized by the Torrent upload, then the download slows down.
Thanks for all the input. It was just an observation, not a complaint.
As for upload speeds, the max I allow torrents is 240 Kb and according to SpeedTest I can get up to 1 Mb. I'll check the settings later today just to make sure.
I haven't reported this to MTS - I don't really consider it to be a problem.
By the way , I have UTV with Lighting.
Don J, remember that Speed Test measures bits per second and most applications use bytes per second (there are 8 bits in a byte).
I would take the Speed Test upload results and divide by 10 for the uTorrent limit. That will leave a little room for ACKs and other traffic.
You are correct. I should have known that !
I changed the settings from 240 KB to 150 KB and now SpeedTest download speeds are consistently around 9 Mb.
Thanks.
21 - 32 of 32 Posts
