41 - 57 of 57 Posts
Yep, that's normal. It definitely is mind blowing to think there's 35 Mbps travelling over that pair of wires.
I don't know what the broadband port would be for so I just did a quick search and someone on another forum said it's for FTTH, so I guess it would plug into an Optical Network Unit if you had an active Fiber line in your NID (grey box outside).
Discussion Starter #42
No kidding, I mean to think about all the info coming through there.....
Thanks for looking into that for me Macman, I went to the "2wire" site, but it really didn't tell me much either.
Now that I know I'm good-to-go I feel better!!!
About the wireless!
There is no additional wireless router. The main set top box - with the hard drives in it has the wireless built into it. Still wireless G but 4x farther signal.
Overall its a great service!!
Just to clarify, the wireless is actually coming out of the 2Wire gateway, not the main set top (VIP 1216). It is not turned on by default. The installer should offer to activate it (contractors get paid extra for networking, so it's pretty much a given) and if they don't, it would normally be $99 to get home networking at a later date (someone with enough knowledge could log into the router and activate it themselves).
With Classic TV, they normally have to put in a router, but the new system is integrated, as someone mentioned, so I think this is why they're offering it for free on all new Ultimate installations.
The installer should write down the wireless settings for you (network SSID and password, as it is encrypted by default).
:D
OK - tried to read everything and make sure I understand the whole install... have a couple of different scenarios...
1) My house has wired network connections as well as coax from a main point in the house, where the phone line currently enters the house as well. Would they install the 2 wire there (maybe in my suspended ceiling) and then take advantage of all of the existing network cable to go from there to my main TV location as well as to my wired home computer? Or would they put the 2Wire by the TV in my living room and then try to work backwards from there? Or would they put it where my existing Modem is for MTS high-speed?
2) My in-laws are thinking about this as well. They have TV on main floor and wired computer up on the second floor (where their current MTS modem is). Coax running from a mian point in the basement to all the other TV's inth house. Trying to avoid having the house messed up too much... same questions as above.... typically where would the installer put the 2wire so they don't have to rip up the walls too much?
Here's the interesting part... Originally, I read that it can be placed in 3 or 4 different locations and that the final decision is up to the installer and the customer
BUT... We were told recently that it is supposed to be placed at the service entrance (where the wires come into the building). That's not always feasible, so I don't know why they changed their mind all of a sudden.
Plus, I've heard that a lot of the contractors just put it at the main TV alongside the PVR when it is a customer who is migrating from Classic, since the old receivers are the source for all the other tv's and the internet. :confused:
Discussion Starter #48
Its really not hard for them to make this work. My installer told me they like to hide it behind the TV....
So if they put it behind the TV, do they need to run Cat5 from the line entrance to the house to where the 2Wire is? Or do they do something similar to the MTS modem and use current phone lines with a filter to get it there?
Discussion Starter #50
one wire is all they need from the phone jack in the wall. (hard to believe) they will likely pick the jack that is closest to your TV.
If it's a house, MTS standards say to run a new cat 5 from the service entrance (a.k.a. demarc) to the 2Wire. If the installer just splices into a regular phone jack that has regular (untwisted) phone wire, they are doing it wrong and it might cause problems. Plus, if the installation gets inspected by MTS' quality control guys, they'd probably make the installer go back a redo it.
The only time I ever feed it off a phone jack is in an apartment because one of the jacks is the main junction (a.k.s. riser) anyway.
Discussion Starter #52
Yes I'm in an apartment...I guess I should have mentioned that. The jack is on the outside wall so I assume its the main junction. I hope.....maybe I should call back.
I think I asked you this macman......but The guy actually hardwired the cat 5 in the all side and ran it to the 2wire unit. BUT on a regular cat 5 the end are large but were it goes to on the 2wire is a regular phone input.
How are they able to change the cat 5 wire to fit the phone slot on the 2wire?
do you think I am losing quality the way they did it?
sorry I don't know the proper terms.......riser? dmarc?
Question re Wiring for new MTS serice
I am currently with Shaw Direct(Star Choice) and will be switching to the new MTS Ultimate. Will they have to change all the wiring or will the Shaw Direct wiring do?
tobe, we have both sizes of connectors that we can crimp on. Some people call them RJ11, but I think the proper term is 6P4C (6 position, 4 connector). You aren't losing quality at all, that's the way it's done on every installation.
The Classic TV system accepted the bigger one (RJ45/8P8C) but the new 2Wire gateway only needs a RJ11/6P4C end. On both classic and ultimate, it's only the two center pins carrying the DSL signal, so they could've been using the smaller ends all along :confused:
ranman, they'll probably reuse some of the Shaw coax if you aren't going to keep that service running at the same time. 99% of the time, people are switching from one provider to another, but I had one tonight where the guy wanted to keep his Shaw service "in case I decide not to keep MTS". I found it weird, but I guess he hadn't given his 30 day notice to Shaw so if he didn't like the MTS system, he wanted it to be easy to stay with Shaw. Makes my job tougher :(
The only wiring that may have to change (or be added) are as follows:
1-Cat 5 line going from the main telephone junction (demarc) to the 2Wire RG
1-Cat 5 line going from the 2Wire RG to the PVR
1-Cat 5 line from the 2Wire RG to your computer (or your existing router if you plan to continue using it in conjunction with the 2Wire RG, which is a router too).
I've probably said it before, but I'll mention it again; Customers can either pack away their router (D-link, Linksys, Etc) and use the 2Wire RG exclusively, giving you full tech support from MTS. Or you can reconfigure your router to work as a "switch" downstream from the 2Wire RG, but it is not MTS' responsiblity to do this. They have generic instructions at http://www.mts.ca/file_source/mts.ca/Static_Files/Raw_PDF/3rd_Party_Router_CustomerConfiguration.pdf
It's not terribly hard to do, but some routers are finicky and act up during the process. Some people don't want to use the 2Wire as it's only "Wireless G" if their router is the newer "Wireless N" standard.
Wireless Internet with the new Ulitimate service
Getting the new MTS Ultimate service hooked up this Friday. Am currently with MTS for internet. Will they automatically put my computer on wireless service with this new modem? Is it something I should have asked for when I booked? Is there an extra cost for this? Thanks
Turning on the wireless transmitter in the 2wire is free at time of installation (normally $99 for MTS home networking). Any computers with wi-fi capability, like a laptop, can usually connect wirelessly fairly easily. A desktop computer without a wireless card is not connected wirelessly for free.
MTS sells wireless network cards for $79.99, or you could get one at a big box store. The installer shouldn't be lazy and tell the customer that they need to make it wireless because running a wire is too much work. Don't believe them if they say that!
HTH!
41 - 57 of 57 Posts
