1 - 2 of 2 Posts
Good evening,
I have a sony 55 inch lcd. I am a rogers customer. I wondering hoe I could mount or attache the HD box to my LCD. I have heard of people opening the box and drilling it to the lcd its self or the mount, then placing cover back in the box.
Is this possible. our advise or thought are appreciated.
Ive never heard of anyone doing that.
you may want to consider mounting it somewhere flat, as the IR sensor on the Cable Box needs to be visible for the remote control to change channels. Most people place it in a cabinet or TV shelf of some sort. Yes even if you mount your LCD to the wall, and hide the wires, you would still need a place to put your Blue Ray and DVD playerrs and such, so you should put the STB in there too, that way the remote can operate it.
1 - 2 of 2 Posts
