I need to mount an antenna to a pyramid roof. There's gutter all around so there's no completely exposed facia, just the couple of inches under the gutter. Pic attached (I hope).
Two questions:
1) how far does the antenna need to be from the gutter to work well? It's going to be pointed almost parallel to the gutter, basically toward the camera in the image above. Do I need to worry about the gutter behind it?
2) suggestions on how to mount this? I've seen some systems that mount to a rafter under the soffit, but if there is something solid behind that exposed bit of facia perhaps that's simpler?
Two questions:
