I've got a Motorola 6416 III 160GB PVR, and I'm interested to know a how accurate the "25 hours of HD recording" is? The reason I ask is because I'm going away for a week, and with all the new shows starting, I have 24 hours and 1 minute of shows that are set to be recorded while I'm gone. I will ensure it's at 0% capacity before I leave, but I want to know if there are other considerations that could affect the amount of shows that can be recorded. I may re-configure my series recordings so some are in SD if you think it's necessary. I really don't want to have to do that, but I'd rather do that than miss out on shows.
My other question is with regards to what shows get priority over hard drive space? I have my series recordings set up in priority order, but what happens when the box fills up? My assumption is that the recording priority has no affect on what's already recorded, but I thought I would ask anyway. That just determines what gets priority if more than two channels are being recorded at once, correct? So how does the device start removing shows to make room for new shows? Does it just start deleting from the oldest show forward (first in, first out)? Is there an effective method of assigning priority levels to shows already stored on the hard drive? I set up some of the more important series to save until 'I delete'. The only other option is until 'Space is needed'. I'm assuming 'Space is needed' would go with the first in, first out rule?
Let me know if you need further clarification. Any tips you have to offer would be greatly appreciated.
