1 - 3 of 3 Posts
Hardly used, asking $399, have all on the original box :
SPECIFICATIONS:
Format: [AVCHD] Video: MPEG-4 AVC/H.264 Audio: Dolby Digital (2ch), [SD-VIDEO] TS/MPEG-2 High Definition Video Recorder Profile: Video: MPEG-2 TS / Audio: MPEG-1 Layer2, Still: JPEG
Lens: Focal Length: 4.5 - 45.0 (35mm film equivalent: 50.0 - 500.0)
F Stop: F1.8 - F2.2
Filter Diameter: 43.0 mm
ISO Settings: 100, 200, 400, 1000
Video Recording Modes (Variable Bit Rate): AVCHD-XP (1920x1080i, 17Mbps) / AVCHD-SP (1920x1080i, 12Mbps) / AVCHD-EP (1920x1080i, 5Mbps) / FHD (1920x1080i, 26.6Mbps) / 1440CBR (1440x1080i, 27Mbps Constant Bit Rate)
Video Recording Time (max.): 10hr (AVCHD-XP) / 14hr (AVCHD-SP) / 33hr (AVCHD-EP) / 6hr (FHD/1440CBR)
Still Image Sizes: [4:3] 1824x1368 / 1440x1080 / 640x480 - [16:9] 2432x1368 / 1920x1080
Interfaces: microSD Memory Card Slot (microSDHC Compatible)
USB 2.0/1.1
USB Mass Storage Class
USB 2.0 High-Speed Data Transfer to PC
1920x1080/60P Output
HDMI(TM) output
Component Video Output
Mic Input (plug-in power)
AV Output
Headphone Output
DC In
Multi-Language On-Screen: 23 Languages (Eng. / Fre. / Ger. / Spa. / Ita. / Dut. / Por. / Rus. / Pol. / Cze. / Tur. / Jap. / Kor. / Chi. [Simple and Traditional] / Per. / Ara. / Malay / Indon. / Thai / Hindi / Swe. / Hun.)
Power Consumption: Approx. 6.6W
Approx. Weight: .98lbs. (440g) [Without battery]
1.2lbs. (525g) [Including battery]
Dimensions (WxHxL): 2-13/16" x 2-11/16" x 4-7/8" (71 x 68 x 123mm)
INCLUDED ACCESSORIES:
AC Adapter
Battery Pack (BN-VF815)
Shoulder Strap
AV Cable
USB Cable
Component Video Cable
Remote Control
Software: CyberLink BD Solution (Win), Digital Photo Navigator (Win), QuickTime component for Everio (Mac)
To save others from having to use Google, this item is a Camcorder......
1 - 3 of 3 Posts
